Hi,
If I buy an off peak return from Nottingham to Reading going via London - if I were to use the return portion of the ticket on two separate days over a week apart would this be allowed? I do not think it would be but thought it would be worth asking.
A regular Off-Peak Return is valid for
2 edit: one day
s on the outbound ticket, and for one calendar month on the return ticket. Some Off-Peak tickets have restrictions on Break of Journey (i.e. stopping your journey early, starting your journey late, or stopping and then resuming, whether overnight or otherwise). However, these restrictions are only allowed to apply to the outbound leg, and hence on the return leg you can break your journey as much or as little as you like.
So yes, you can indeed use it over two days within a week - as long as you're not making the same part of the journey twice. Obviously, this all doesn't apply to Off-Peak or Anytime
Day Returns, which, like the name suggests, are only valid for one day.
If you are looking to buy this ticket, you could probably save a significant amount by either getting Advance tickets, or by getting a Railcard if you are eligible for one (it would be worth it just for this one ticket alone), or by 'splitting' the tickets - this can best be looked up using the
www.trainsplit.com website. Basically, splitting means getting two or more separate tickets to cover your journey, rather than getting one through ticket. It can often save money due to the many anomalies and variations in the ticketing system (but is totally legal as long as you stop at the station(s) where you change from one ticket to another).
