Off Peak Restrictions Query
J663738
20 May 2025
I bought an Off Peak Return ticket a while ago from Cardiff to Weston-Super-Mare. I'm well aware that Off Peak can't be used during the morning period. But when I wanted to return, I thought I wonder does Bristol Temple Meads have an evening restriction like London and Birmingham? I checked and checked on line but just seem to go around in circles, no where could I find a definitive answer.
In the end I caught a bus from Weston, which I knew would get me back into Bristol well after 7pm and avoid any potential penalty fare.
My question is, are off peak restriction times for major stations listed anywhere, especially for journey's between 4pm to 7pm ?
jfollows
26 Feb 2011
Wilmslow
An off peak day return Cardiff to Weston has restriction code W4
Restrictions​
Applicable Days​
Monday to Friday
Mondays to Fridays
Outward Travel​
Outward Travel
Not valid on trains timed to depart after 04:29 and before 08:44.
Return Travel​
Return Travel
You can look up any restriction code, which will be on the ticket, in the same way.
If this was the ticket you held, then there were no restrictions for your return journey in the afternoon or evening.
Important: the restrictions that apply are determined by the ticket you hold, not by the location. There are no off-peak restrictions for any stations. However, some of the off-peak tickets from those stations might have restrictions.
Djgr
30 Jul 2018
Off peak restrictions vary by ticket type rather than by station alone.
You should be able to find the relevant code on your ticket (in your case W4) and go online to identify any restrictions associated with the code.
Mcr Warrior
8 Jan 2009
Believe Cardiff (Central) to Weston Super Mare return tickets are only available as Anytime Returns, Anytime Day Returns and Off Peak Day Returns.
There isn't an Off Peak Return, as such.
The Off Peak Day Return isn't valid 0430–0843 in either direction, as @jfollows has helpfully pointed out, other than, of course, at weekends or on Bank Holidays.
J663738
20 May 2025
No wonder people find UK ticketing rules complex.
Yes it was an Off Peak day return, I didn't see any codes on it, but will know for next time.
So you are saying if the restriction is not printed on the ticket, then its ok
jfollows
26 Feb 2011
Wilmslow
J663738
20 May 2025
I have found another ticket to Swindon I travelled yesterday and now do see the W(2) code.
It also has 'Valid only via Newport', since it doesn't say which Newport, could I go via Essex!
Tried to edit the url to see all the different types of restrictions, but get a 404 error. Why are they hidden?
To be very honest I never paid much attention to it as the web address was nre.co.uk which I did not recognise.
Thanks!
Mcr Warrior
8 Jan 2009
Just to clarify, what are/were the relevant origin and destination stations? Presume one is/was Swindon (Wilts)?
jfollows
26 Feb 2011
Wilmslow
Penarth (or Cardiff) to Swindon ‘via Newport’ is valid via Gloucester, Cheltenham, Bristol or Bath as it happens. As well as Badminton of course.
Map LW at https://rgpp.iblocks.co.uk/maps
Restricting the ticket to ‘via Newport’ doesn’t seem to achieve much.
(There is no “any permitted” or even “.” ticket)
J663738
20 May 2025
Yes found the map (thanks), so are you saying I could route via Gloucester or Chelthenham for instance and break the journey there? and this would be acceptable?
Djgr
30 Jul 2018
Thanks!
Well the nr is National Rail. Not sure what the e stands for.
jfollows
26 Feb 2011
Wilmslow
Yes, provided the ticket allows break of journey, which would be the case for the tickets I can see.
(All tickets allow break of journey unless their restriction codes say they don’t.)
J663738
20 May 2025
Sorry to be a pain, Suppose someone bought a Cardiff to Bristol ticket and then routed via Gloucester and stopped there (as that was there real destination, then returned to Cardiff via Bristol.
Wouldn't this effectively be getting Cardiff to Gloucester ticket on the cheap?
I am sure there must be hundreds of examples like this around the country.
jfollows
26 Feb 2011
Wilmslow
Cardiff to Bristol isn’t valid via Gloucester. Map SN applies here.
Cardiff to Swindon is valid via Gloucester etc. per map LW.
You’ve got to know your end points first before looking up valid routes in the routeing guide.
