Off peak - by company?
neonison
25 Feb 2007
Standedge, One hill, four tunnels
i understand that different TOCs have different off-peak periods.
When attempting to check the validity of an already purchased off-peak ticket on-line, the TOC (LNER) referred me to the NR planner which was not working.
Is there a guide listing all companies and their off-peak periods?
Hadders
27 Apr 2011
You ticket will have a restriction code on it in the format NRE.co.uk/xx
This will give you the restrictions. Hey are not by company but by individual ticket.
Merseysider
Fares Advisor
22 Jan 2014
Exactly as @Hadders states.
In case you have an ‘old’ style ticket, the 2-digit code will be in the bottom right-hand area of your ticket.
neonison
25 Feb 2007
Thanks. That is the link I could not get to work but seems OK today, after the event.
To be clear I arrived at KGX earlier than anticipated at 16.45 with an off-peak single but was given wildly conflicting guidance on what was the first train I could take.
I was valid.
Haywain
3 Feb 2013
Much as most TOCs would like to have a black and white definition of peak and off-peak, it is actually defined by the specific restrictions of the ticket that you hold. On a train at "peak time" you could quite easily by using a Super Off-Peak ticket that is entirely valid while the person next to you requires an Anytime ticket for their journey.
Which train you could use from Kings Cross would depend on the ticket you held - the ticket type, origin, destination and route all influence this, summed up in the restriction code.
neonison
25 Feb 2007
...but it is still mightily confusing when the information desk (near Platform 9.75) tells you one thing (at or after 18.00) the guy at the gate line another (after 18.00) and I could have alighted from the train had I heeded the (after 1900) announcement after boarding that off-peak tickets were not valid on the train. The code was 1T.
Haywain
3 Feb 2013
So two people gave you the same information, which was essentially correct. The announcement on the train would (or should) have referred to Super Off-Peak tickets and would be correct in that respect. It's hardly "wildly conflicting information".
ForTheLoveOf
7 Oct 2017
Several trains off Paddington in the evening (long distance) are advertised as Anytime to Reading, Off-Peak to Swindon and Super Off-Peak beyond. It can get quite mad.
They may be advertised as such but it is not correct - the trains you can take depends entirely on your ticket's restriction code. For example, passengers coming from Peterborough could entirely legitimately travel on any train to Reading if they were using a Super Off-Peak ticket.
I think it could be somewhat more acceptable if they qualified it by saying, "For passengers using tickets to/from London, trains are classified as below ...... for passengers using tickets to/from other stations, please enquire for advice."
I don't think anyone can legitimately argue that the difference between Peak, Off-Peak and Super Off-Peak is confusing because it absolutely is! Even on here we will occasionally have disagreements between whether ticket X is valid on train B or someone will miss-read a restriction code or miss that for journeys via G you need to refer to restriction code 8A rather than code 3T.
However, as noted on many threads, fixing this problem is not going to be easy without either making long distance travel very much harder (and/or expensive) from/to/via London (and other places but I think London in particular struggles with this issue).
Esker-pades
23 Jul 2015
Beds, Bucks, or somewhere else
That may be done already and I've forgotten they do that, or they don't. I can't quite remember, sorry.
Mag_seven
1 Sep 2014
here to eternity
I noticed a VT poster at Euston the other day that had the usual list of "peak" trains but a note stating that "certain" off-peak tickets may still be valid on those services.
ForTheLoveOf
7 Oct 2017
Then they're not "peak" though, are they?!
cactustwirly
10 Apr 2013
They even have a poster, detailing the trains you can and can't catch, to make it 'simple'.
All well and good, unless you have a ticket that isn't set by GWR, whereby all of that information is irrelevant.
