This was my first ever PTE (or anything even remotely similar!) Challenge and, as per usual, I have fallen flat somewhere between the last hurdle and the finish. I had a faster time but one less station! And if I continued to Longbridge at a certain point (Mojo knows this) I would have had enough stations, but a slower time! Worse was that Lichfield TV issue; I reached New Street at 12:37 only to see a Lichfield train running two minutes late pulling out! If I hadn't dawdled and wandered into WHSmith, I could have caught it and pulled out an extra station or two, thus winning!
I always seem to come second in things like this. Can't I come third? And not have the misery of being that close? Or at least have a score of, say, 4 less? Worse, I have found a way to increase my score by one point
and cut ten minutes off my time! I am absolutely disgusted with this result. I even threw a "hissy fit" [actual quote] at Moor Street when Mojo said his team had scored 37. Yes, he knows Birmingham better than me (by far). But I could easily have won! And with a little optimism (and a non-dawdle at New Street) I could have scored 40! Argh!
All right, rant over. Now some actual notes. Somehow, Mojo et al and I managed to choose the same first journey, which involved a walk to New Street. But I got off the 350 in question before they did, and then I saw no-one again until Moor Street. All of my times, bar one [-3], were [-1], [0] or [+1] minutes, which is really boring! And I even went 47 minutes without scoring courtesy of something called a "bus". I was inundated with 323s; had a couple of 150s, the above 350 and a 153/170 combination.
Afterwards, we went to Pizza Express and spent almost £100 between six of us!
I eventually left on the 21:12 to Bristol TM, but not before a photo opportunity with Mojo at B'ham Int (in which he unsurprisingly but also [probably!] unwittingly proved how poor I am at photography at present!
When planning my route, I had the figure of 36 as a target. I wanted to beat it, but I couldn't. Now I know a way to do so, which involves only a minor modification (admittedly to that shared journey with Mojo et al). If I follow exactly the same route for NWM II though, the score will still be 36... no Bordesley boost, so I'll still lose by one point :mad:
Well done to Mojo, ChrisTheRef and AsylumXL on their victory [he says, grudgingly!
]. Come London though, I'll show you want I can really do...! (I can be very competitive sometimes. Also, I have proven that I can't use cutlery very well...!)
EDIT: Time for some controversy. Can I claim that you all cheated with that 323 issue?
EDIT: Ah, yes; the new avatar. Good job Mojo
