Nuneham Viaduct shut - Didcot- Oxford
DelW
15 Jan 2015
I wonder how they're going to put piling in with the bridge in the way. Normally when you see videos of these piling machines they take up significant vertical space. Sounds tricky!
There are low-headroom (and low-tech) options for installing piles, but they tend to be slower and therefore more expensive than conventional rigs. I once had to use one to install piles for a bridge abutment, as apparently no-one had noticed until we started on site that it was located directly below a National Grid HV line.
GRALISTAIR
11 Apr 2012
Preston Lancs
Shocking.
snowball
4 Mar 2013
I've seen somewhere that the piling in the river will be sheet piling. I don't know if that requires less headroom than some other types of piles.
Meerkat
14 Jul 2018
In the last video linked there was a compound full of what looked like tubular piles.
I don't understand the headroom questions - bang the piles in either side and then have beams across to support the bridge.
jfowkes
20 Jul 2017
I think I misunderstood a particular sentence in that last NR video. He said:
We're now moving the barge into place with the piling rig, so it'll be under the bridge so we pile those supports.
I interpreted this as piling under the bridge, but yeah it probably just means that the barge is under the bridge.
Eddd
8 Apr 2018
Dan G
12 May 2021
Exeter
Once the bridge is supported the entire pier and embankment will be replaced. I wonder how that will be done? How will the track be supported while what is underneath is removed and replaced?
Meerkat
14 Jul 2018
I don't think you want to interpret 'under the bridge' all that literally.
The track has already been taken away
Dazza12
10 Aug 2022
Derby
I suspect that the track has already been removed...
TurboMan
5 Apr 2022
GWR ran 2 ECS moves today, 5Z01 and 5Z02 from Oxford to Radley, anyone know what this is for? Just crew knowledge, or preparation for some kind of potential shuttle?
Pilot working to and from the point of obstruction is being suggested for Oxford - Radley and Didcot - Culham.
BrianW
22 Mar 2017
I was imagining trains reaching to both sides of the river and 'sherpas' with mules carrying memsaab, his mother-in-law lady muck and maid through the waters :|
mr_moo
7 Sep 2009
Cambridgeshire
No - those piles are too large for OLE work.
Not neccesarily. OLE piles come in various sizes to support the ground conditions. I know of ones up to 1m diameter, although most are smaller of course.
They don't look like the standard OLE design ones either.
The piles visible in the video are CHS ones - "Circular Hollow Section", a standard type of pile used in an array of differing applications, OLE foundations just being one if them. They are fairly easy to procure and install so are the obvious choice when you are in a hurry. Usually vibrated and/or hammered down into the ground. Sometimes the centre is left as-is, sometimes it's excavated and rebar and concrete poured in, to make it much stronger. For this appliction they will almost certainly be infilled with concrete.
They also come in sections which is helpful for construction. You can bring them in a length suitable for the plant and access you have, then drive that in, weld a new section on top, then carry on driving down, weld, drive, repeat as required for however deep you want to go.
fishwomp
5 Jan 2020
milton keynes
How? Bridge is north of Culham. Not many passengers though, only the few for UKAEA/JET Culham Lab
So it is - I thought it was the other bridge south of Culham, my bad!
In that case - a shuttle bus between Radley and Culham would fill that gap nicely.
jochta
7 Feb 2017
Abingdon
Radley and Culham both serve several hundred passengers a day. Culham has regular commuter traffic in the mornings as well as incoming passengers for the labs. Appleford is much quieter but it has a limited service and catchment.
Meerkat
14 Jul 2018
Really - won’t they want to hoik them out again after the bridge has been fixed?
considering what is holding up the other end of the span, and presuming nothing heavy will be going over it surely a few hollow ones will be up to the job?
Or are you talking about piling for the new embankment?
mr_moo
7 Sep 2009
Cambridgeshire
I was thinking about the permanent piles for the new abutment - sorry, that was a bit unclear.
You have a point re the temporary piles - they may not be infilled. It would depend on the ground conditions etc.
Northampton
The temporary piles in the river itself will presumably need to have something inside otherwise they risk being dislodged by a strong current?
class ep-09
5 Sep 2013
It’d have to be Niagara Falls grade current to dislodge 25m pile of this kind ( that’s what was told ).
plugwash
29 May 2015
I'm pretty sure the 25m was reffering to the permanent piles for the new embankment, not the temporary ones in the river.
The time of year helps, river flooding mid April and May would be very rare.
River flooding tends to be late Autumn - Winter or if get long thunderstorms in summer.
Northampton
I am assuming thar this temporary fix may well be needed for longer than 6 months.
plugwash
29 May 2015
There was talk of a temporary fix early on, but that doesn't seem to be the current plan.
The current plan seems to be to put temporary piles in the river to hold up the bridge deck during works, then dig out the abutment and re-build it on new piles.
hwl
5 Feb 2012
Propping the southern deck will only be needed in the short term till they get the abutment and embankment demolition completed and new piled foundations, abutment for the surrounding embankment area built and then the railway restored. At which point the temporary prop structure can be removed after train are running over the summer.
I have misunderstood then, I thought aim was to get a temporary support so pier could be demolished, piled rebuilt, and bridge jacked onto the new pier by 9th June. After which the temporary supports will be removed whilst line is open.
Northampton
Maybe I've misunderstood. I thought intention was temporary prop structure to be open by 9th June so they can properly fix the issues with the embankment. I may very well be wrong.
