Nottingham - Bath Spa Return
MCR247
7 Nov 2008
On Thursday I'm travelling to Bath Spa, and I'm travelling back on sunday. Can anyone help find cheap fares? Leaving on Thursday morning returning Sunday afternoon
Thanks
krus_aragon
10 Jun 2009
North Wales
Assuming you can travel off peak:
Regular Off-peak return NOT-BTH: £60.50 (SVR, valid after 0930)
Breaking at Cheltenham:
NOT-CNM: £37.60 (SVR, valid after 0930)
CNM-BTH: £19.00 (SVR, valid after 0833)
Total: £56.60
If you want a decent journey, look at going via London. However cheap AP fares will have sold out for this journey weeks ago, so I doubt that would be a viable option now.
So you are probably stuck with the abysmal service by Cross Country, although if you time it right you can get a real train and therefore probably a seat, from Derby to Bristol.
The full fare (no railcards) is £60.50, so just try splitting at various places. e.g. NOT-CNM is £37.60 and CNM-BTH is £19.00, therefore that's down to £56.60 already. Cross Country's fares are generally the worst value in the country, so if you can find fares set by other TOCs then that lowers the cost.
The cheapest walk-on method of going via London is Nottingham-Stroud (£42.00) plus Swindon to Bath (£11.00) totalling £53.00 however you will struggle to get through the LU barriers as the staff are poorly trained and don't understand what the Routeing Guide is, they are 'programmed' only to look for a "+" symbol which isn't on this ticket. Bring the relevant documentation from the RG if using this ticket. I did it once and was only questioned at Kings Cross St Pancras on LU (Paddington is not a problem as the LU barriers could be avoided, and I think they have been removed completely now and replaced by FGW ones), after a 'discussion' I was allowed through.
Looks like ATOC have removed the "LONDON" route option for that flow :(
There should be a law that states that ATOC cannot change the RG without permission and advertising all the changes, and only once a year.<(
Railjet
28 Feb 2009
If you don't mind bit of a detour, the SVR fare split at Worcester is £49.10.
