Northwich station gets hump (instead of rebuilt platform)
Waddon
15 Sep 2009
In those pics the hump seems to still leave quite a step up to the train...
ANorthernGuard
8 Oct 2010
The infamous Harrington Hump!, it may look daft etc. but it does do the job, because of the height of Northwich (both platforms) it would cost too much money to raise the platforms so this is the cheapest and most Practical option, its just up to us Train Crew to tell the driver where to stop! lol
northwichcat
23 Jan 2009
Northwich
On the last picture it looks like the 156 has stopped in the perfect place to allow 2 sets of doors to be boarded/alighted at 'hump level.' However, I imagine with the many 142s that appear on the line it would be more difficult, especially if the train is packed and only one carriage has standing room left.
ANorthernGuard
8 Oct 2010
depends on just a cpl of things really
Type of Traction
What Formation it is in
East/West type
Single or Double Set
If any are locked out which set
apart from that..easy lol
northwichcat
23 Jan 2009
Northwich
Type of Traction
East/West type
Probably on a normal weekday the only service that may cause an issue is the 15:07 Chester-Manchester for two reasons:
1. Different guards open the rear unit at different stations: sometimes it's Greenbank, sometimes Northwich, sometimes Knutsford.
2. Unless it's 150/2s and/or 156s it means that corridor connections can't be used.
Almost always if it's one unit being used out of two it's the rear one that's locked out of use and as there are no reversals on route it stays that way. Quite often if the rear unit is locked out of use the driver stops the train where he/she would normally stop it if there was no rear unit sometimes with part of the rear unit hanging off the back of the platform.
The only time I've been on a train where the front unit was locked out of use was when there was a problem with doors jamming on the front unit. However, I appreciate if that did happen it would cause a problem at Northwich in the Chester direction given that the driver can't go past the signal meaning the hump then can't be utilised.
