wilbur1985
There is now 5Z heacode runs to and from Scarborough is this just driver training or route learning?
Route retention for the York drivers who previously route learned and for any new York drivers to route learn it. Seems to happen every couple of months for a couple of weeksThere is now 5Z heacode runs to and from Scarborough is this just driver training or route learning?
If you want to use a Northern Only ticket/pass to travel from York to Scarborough at present, you do indeed need to travel via Hull.Ok, even though these runs are through Malton as to get to Scarborough with northern you have to go to Hull and change?
There were plan pre covid for northern to run via Malton to create 2 trains an hour with TPE but that got kicked into the long grass after covid but they've kept drivers knowledge up for train swaps and if it ever takes off for northern to provide a serviceOk, even though these runs are through Malton as to get to Scarborough with northern you have to go to Hull and change?
Isn't there refuelling available st Scarborough TMD?The aim of Northern drivers signing York - Scarborough is to allow units to be cycled for fuel/maintenance when the South end of the Wolds Coast is blocked. For example shut Beverley to Hull for a week and you eventually run out of fuel and exam miles to run between Beverley and Scarborough.
Funding was recently confirmed by DfT and the planning application is already being processed. Definitely a case of when not if. But completion date is being touted as 2028.I doubt the half hourly service will be introduced until when/if Haxby station is opened?
Don't think Northern have ever used it. Either way no repairs or exams could be done either way.Isn't there refuelling available st Scarborough TMD?
There's also a use our trains only option on the NORTHERN appIf you want to use a Northern Only ticket/pass to travel from York to Scarborough at present, you do indeed need to travel via Hull.
If you are using a Northern Only pass, you may want to use www.fastjp.com and in the advanced options select Northern Only to obtain itineraries.
I'm surprised that the benefits of Northern drivers retaining this York - Malton - Scarborough route knowledge are outweighed by the costs in drivers' training time.Route retention for the York drivers who previously route learned and for any new York drivers to route learn it. Seems to happen every couple of months for a couple of weeks
More over, if you think about it maintaining the compentency of Driver Managers and Trainers, who will eventually train the crews who... at some point... will work Northerns passenger service between York and Scarborough.I guess the thing is they've realised that maintaining route knowledge is comparatively simple compared to regaining it once it's lost.
Virtually all units (Not quite all services are operated by Class 170) on the Hull to Scarborough Line (Yorkshire Coast) are based at Hull BG so rotate back to that depot. No Northern units are left at Scarborough on a night. Scarborough has a light servicing point operated by Arriva for Transpennine Trains for 185 units. Northern don't use it.
Hull does do heavy maintenance B Exams as well as A Exams. The depot has pit roads, overhead cranes and lifting jacks and once the latest improvements are delivered will undertake underframe cleaning at the end of Number 1 Road. Unit allocation is much more than token gesture. Units are allocated and generally return for regular Exams and other servicing and repairs. Hull looks after 155 and 170.
You don't even need to do that, if a 170 needs to go to Neville Hill, it is put in diagram BG362, which does the 0519 Sheffield, goes on Scarboroughs all day, ends at Hull at 2015, then attaches to form the rear of the 2115 Halifax, and detaches at Leeds for a booked XNL finishNo need... put them on a 2Rxx. Swap them out at York to 2Cxx to finish XNL, or if really needs be... ECS from HUL LDS XNL as happens now.
As for Hull, you may have missed this Northern Press Release - Upgrades to Hull depot to deliver first class service for passengers across Yorkshire - December 2022.
