Northern Unit Refurbishments and depot allocations.
Ben Anslow
13 Jul 2017
Lancashire
Just a question 195s are nearly 7 years in service so they will soon due a c6 overhaul not sure if has been mentioned in thread before but anyone got any idea on when the will start going through
MrBeanie
14 Jun 2026
west yorks
Re the 195s. I was under the impression 195104 is damaged and out of service. But does anyone know what the situation is with 195115 and 195116 as neither of those appear to be in use.
david l
27 Dec 2016
Wigan
I thought that 195 104 was back in service now
Not sure if the work on 195104 has started yet, if it has it's quite recent and you won't see it for some time. Went to Wolverton initially but is it now at Brodies??
dave87016
9 Dec 2008
Lancashire
150114 156469 and 158851 went ECS from Neville Hill - Heaton TMD today ( 1st July 2026 ) , I presume with a 150/1 in the consist they are going for some kind of work or exam
skyhigh
14 Sep 2014
C6 for the 150, I would guess C4 for the 158.
The 156 was just at Neville Hill for tyre turning as Heaton doesn't have a wheel lathe.
diligentdave
20 Oct 2007
Class 195's and 331's don't have heavy exams like the older fleets do. They have the C4 and C6's integrated into their existing running maintenance, therefore stay at home depots and don't go to works.
Both require wheelset changes. The availability of Class 195 wheelsets is very sporadic. 115 isn't due to be released until October, whilst 116 might be out in August.
You will not see 195104 for a long time. Possibly 2028......
156 ex-tyre turning, correct. 158851 hit a big rock and needs repairs. 150114 was going for C4 overhaul.
43096
23 Nov 2015
There's some serious questions need asking as to why that has taken so long. It took almost four months to move it to a "works". That was two years ago. To say it could be another 18 months or more for what does not seem to be the most complicated repair ever undertaken, is frankly pathetic.
MrBeanie
14 Jun 2026
west yorks
Thanks for the update, that's very helpful.
Will have to try and get up to Carlisle/Newcastle for the 156 units as they don't seem to leave those areas that much
1D53
2 Apr 2006
The 156s have no real way to leave the North East with the Cumbrian Coast closed. The only way they'd rotate through to Barrow and then down to Preston/Manchester would be this way.
diligentdave
20 Oct 2007
Have you ever repaired a train that's been involved in an incident like this? Once you start uncovering stuff it takes on a whole new level. CAF are not the most helpful of companies to work with and the lack of relevant information available is frankly shocking. To repair a train, first you need repair procedures, of which there are none.
Northerngirl
16 Aug 2023
Wirral
It would never happen, but since they could probably get a new car/set built in less time, the gear must still exist
skyhigh
14 Sep 2014
You can bet that CAF would charge a huge amount for a one-off unit, assuming they were actually interested in building it.
dave87016
9 Dec 2008
Lancashire
Sunday 5th July northern 150 transfer swap moves as follows
5Z51 13:15pm Newton Heath TMD - Neville Hill TMD formed of 150124 150125
5Z52 15:44pm Neville Hill TMD - Newton Heath TMD formed of 150215 150269
david l
27 Dec 2016
Wigan
Interesting. 150124 not on the original list supplied from Northern as part of an FOI (not by me!)
Later 5Z51 has run but with units previously allocated removed. Anyone eyeball it en-route??
150124/5 are today working off NL so presume they were the 2 moved on 5Z51.
150215 is today working off NH, whilst 150269/73 are not in traffic, presumably being acclimatised at NH.
MrBeanie
14 Jun 2026
west yorks
150125 was working in and out of Leeds today. Caught it at woodlesford going back to Leeds.
Much more surprising was 155341 on the 11.27 Leeds to Halifax service, didn't see it again though.
For anyone interested the ecs working from heaton to newton heath on Saturday afternoon was 156416.
Peter A
20 Feb 2019
A 155 is allocated to the 10:15 Hull to Halifax and return 12:15 Halifax to Hull where the unit then heads to Hull Botanic Gardens
david l
27 Dec 2016
Wigan
Does anyone have a number of how many 150/2s have transferred to Newton Heath please?
At present 150201/05/06/10/11/14/15/18/20/28/68/69/71/73, (14 in total) have gone NL-NH, leaving (10) 150203/04/22/24/70/72/74-77 still to move. 150225 was always a NH set so in theory 25 150/2's will then be based at NH.
Going the other way from NH-NL so far have been 150105/14/15/21/22/24/25/27/31/34/35/45/50.(13 in total)
On the original list and still to go are 150103/07/09/10/20/29/30/42/44/46/48 (11 in total) but 124 has gone from NH-NL and wasn't on the original list so presume one of the others won't!
978wta
5 Dec 2017
Huddersfield
Thanks.
43096
23 Nov 2015
You have rather proved my point. As I think many of us suspected, the shambles that is CAF is to blame. I'll stand by my diagnosis of pathetic - with finger pointed firmly at CAF.
Killingworth
30 May 2018
Sheffield
Performance of 195s so far, after less than 7 years in service, augurs badly for units intended to keep running for 30+ years. Hopefully after sales follow up will be a more critical part of future train orders. In the meantime Northern, Eversholt Rail and the DfT must surely be putting pressure on CAF to resolve the current issues.
Hopefully they already are but commercial and legal diplomacy probably limits what we can be allowed to know. A minefield of legal contract terms and conditions?
MrBeanie
14 Jun 2026
west yorks
Do we know if the transfers planned for the 10/07 are going ahead (for 155345 and 156488). If so, where are they likely to return to.
Also, is 156449 still in service or is it out of use (potentially planned for refurb ?)
Trainz6013
4 May 2024
Earth
I believe 156449 is at Wolverton, if I remember right it was getting some work done at Heaton, but was so badly corroded they sent it to Wolverton instead
