Northern Unit Refurbishments and depot allocations.
Starmill
18 May 2012
Bolton
You can board through those doors in the middle of a formation, or through the guard's door of course, but sometimes the doors behind behind the driving cab are not enabled.
LOL The Irony
29 Jul 2017
Chinatown, New York
As far as I'm concerned, they're only open when operating in multiple. I've had a /1 operating in multiple with that door unlocked but that's a story for another day.
Overspeed110
16 Nov 2017
The cab end door on a 150/2 does not operate from the inside or outside passenger door controls when that ends cab is keyed in. It becomes an emergency exit / crew door only.
978wta
5 Dec 2017
Huddersfield
Thanks for the answers. Although to keep in line with the /1, I think they’d look better painted blue rather than white.
Chrisyd
16 May 2015
Hopefully it is because they always plan to run the /2's in 4 or 6 coach formations so those doors will be usable!
northwichcat
23 Jan 2009
Northwich
Some of the /2s will become centre cars for hybrid 3 car 150s. I understand it'll be ones with Asbourne seating that will become the hybrid sets.
61653 HTAFC
18 Dec 2012
If the doors are not a contrasting colour, they can't be used for passengers even when operations allow it (rear/centre cabs). I don't see why Northern would do this just to make the units look "nicer".
Geeves
6 Jan 2009
Rochdale
319431 is back at Allerton after its recent efforts to set fire to its self.
Here is how the 170 is coming on (not sure which sorry)
dazzler
6 Apr 2018
York
According to the March 2018 LNE Sectional Appendix, class 170s are not currently cleared for Leeds - Harrogate - York.
I don't know what needs to be done to make them fit, it may be as simple as they have never been gauged for the line, so a gauging train needs to be run to prove they are in gauge, or they may need slightly more drastic surgery! ;)
northwichcat
23 Jan 2009
Northwich
I don't think 170's are cleared for the harrogate route yet. Not sure what needs doing to make them fit.
K
Might be the necessary paperwork just hasn't been done. I don't ever recalling hearing about clearance issues with using 170s, unlike 175s and 185s.
PHILIPE
14 Nov 2011
Caerphilly
The tendency has come to list in the Sectional Appendix just the routes the traction is intended/diagrammed to work over but in practice they can but just needs checking out and can be done in retrospect. A recent example being Class 170s not being authorised to work beyond Bristol Parkway which has resulted in trains having to be turned back there instead of completing their journey to Bristol Temple Meads nothere as has happened on several occasions. It would seem there would no problem in running to Temple Meads and common sense has now prevailed and it is now shown in black and white that they can. When the Class 175s came out and eventually working on ATW they were not listed as being able to work between Cardiff and Cheltenham but ATW wanted the flexibility so they were "cleared" respectively after a gauging check trip.
AMD
6 Dec 2017
The issue with Leeds - Harrogate - York with the 170s is that Network Rail are going to adjust the clearance at Burley Park.
Kieran1990
29 Feb 2016
Chances of NR getting it done before May timetable change? Also what is the clearance issue at Burley Pk?
AMD
6 Dec 2017
There's a possession planned in before the TT change in May to fix. I think it's platform clearance.
978wta
5 Dec 2017
Huddersfield
My take on how the 150 hybrids MAY look. The centre car is a /1 as the /2 is slightly larger in game. I think some of the decals may be lost or rearranged to suit.
NorthernSpirit
21 Jun 2013
I think the decals on the /2 would be removed and the crew door being painted white so it blends in with the rest of the unit. Even though the above is CGI I do look forward to seeing some hybrids running about - at least they'll be more seats.
Geeves
6 Jan 2009
Rochdale
Another 150 went from Newton Heath to Doncaster on Saturday as 5Z53 but I couldn't get out of the office quick enough to get the number! I guess Brel man will know.
61653 HTAFC
18 Dec 2012
Does that mean I'll have to re-register, I wonder...?
More significantly, once the free WiFi as promised under the franchise agreement is rolled out across the diesel fleet, will it be the same system?
LOL The Irony
29 Jul 2017
Chinatown, New York
The crew door is used by passengers when working in multiple and I doubt that'll change when they are shoved between a /1.
