One certainly has argued that. However, it is certainly problematic with some products such as PlusBus which are, currently, only recognised reluctantly by some bus drivers.
I wonder if switching to thermal roll and thus making it look
more like a bus ticket might help with that.
Yes our TVMs have both types of printer, the paper roll one not currently used, but will be as part of our trial to print on that type of roll stock
That sounds good. Thermal roll tickets should be an improvement in the long run.
Yes, personally seen it loads of times. It was particularly bad when you just had to press a single button to print them, now you have to input a journey which has reduced the issues but it does still happen.
Yes, I used to walk past my local station and see literally dozens of the things strewn all over the ground - perhaps worsened by the fact that this particular station is above street level so "print loads of tickets and throw them off the bridge" was probably quite an entertaining pastime for bored teenagers.
I'm sure I recall reading that Plusbus is moving to barcodes, presumably ones recognised by Ticketer and that other common system Stagecoach use?
I thought barcode scanners were an optional module for Ticketer? I don't think Stagecoach have them at all! For me, the correct solution for Plusbus is to get rid of it and replace it with proper fare integration, but that's for another thread.
If Plusbus is going to be issued with barcodes, it is vital that bus ticketing hardware which has a barcode scanner accepts them. If the driver sees a ticket they don't recognise and has no way of checking it, they are likely to give benefit of the doubt. If the ticket has a barcode and their machine has a barcode scanner, and the machine rejects it, they almost certainly won't.
To return (somewhat) to the topic, is the plan that TVMs will issue barcodes for Plusbus as well, or is it just an online thing?
