Northern Stock on Various Routes
Daimler
5 Feb 2009
Hertfordshire
With regards to a trip up to Lancashire I'm planning next week, what stock can I expect on these (Northern Rail) routes?
Liverpool Lime Street - Blackpool North
Lancaster - Morecambe (was a 156 last time I was up there, is this standard?)
Morecambe/Lancaster - Leeds via Hellifield (a Pacer, I think, but not sure...)
Leeds - Carlisle via the S&C
Thanks! :)
Pumbaa
19 Feb 2008
Liv - Blackpool: 156/150
Lancaster - Morecambe: 153/156, usually 153s.
Leeds - Carlisle: 158/156/153
driver9000
13 Jan 2008
Morecambe-Leeds via Hellifield is usually a 144 but can produce 142s as well. 150, 156 and even 158s have appeared before now too.
142s can also appear on the Blackpool-Liverpool service although this is unusual during the week.
Settle & Carlisle is normally a 158.
With Northern anything can turn up regardless of booked traction. Have a great trip!
MCR247
7 Nov 2008
When I was in Blackpool, I saw about 5 Liverpool trains and they were 142s every time
ukrob
15 Jan 2009
They are only every hour. Are you sure you saw five?
Anyhow, as has been said, they are booked for, and usually are 150/156.
MCR247
7 Nov 2008
I'm sure the 0900 service from Leeds to Carlisle on Sundays was or is booked 3x153s. Thats what I heard anyways
I was there for a week :(
ukrob
15 Jan 2009
What did you do to deserve to be in Blackpool for a week? :(
In addition to what has already been said, I think one of the late evening Liverpool - Blackpool services is diagrammed for a 142.
87015
3 Mar 2006
GEML/WCML/SR
It won't be 156 - none are based at Neville Hill anymore, 158's are the primary unit used, I can't remember the last time anything else worked it...
Well you haven't remembered the daily booked 153 strengthener Leeds-Carlisle and return then. Its part of the "Penzance to Carlisle by rocket" challenge....
158757
14 Aug 2007
Booked 150/156
Usually 156 with some 153's, Leeds through services will be a pacer or 150.
More than likely a 144. 0819 Leeds-Morecambe/1034 return is booked 150.
1019/1329 return is Booked a pacer and has to be as it runs through to Heysham which only Barrow crews sign, and they don't sign 150's.
1349/1619 return is booked 153+144, but can turn up a 142 vice 144, 153 will be locked out as it is detached at Lancaster on the outbound leg
1639/1908 return is booked 144, can turn up a 142. 153 attached at Lancaster on the outbound leg, but is locked out of use as it is removed at Skipton on the return journey (used to be, haven't done the service for a few months)
0849/1151 return is booked 158+153
0947/1400 return is booked 2x158
1049/1503 return is booked 158
1249/1618 return is booked 158
1449/1807 return is booked 158+153 (same set that does 0849/1151)
1756 is booked 158 and stables overnight to form 0853 ex-Carlisle next day
1919 to Ribblehead is booked 158 and stables overnight at Skipton.
