northwichcat
Is this so the Airport-Scotland services become 100% electric?
Yes
(Apparently you can't post a message with just Yes as the reply because it's too short!)
Just as s***!No idea what they are like once they get onto OHLE though.
Just as s***!![]()
Apparently Porterbrook did computer simulations to show how they would fair in comparison to other EMUs and the results they got weren't good on stopping services which is why they came up with an option for faster acceleration.
So are 319s able to draw power from the BML 660/750 DC supply to equal that taken from the MML 25kV supply?
I've not seen anything that actually states the 319s acceleration means they can't be used on this line. As for not suitable for metro work, they've been doing that since they were built.
They do accelerate better on AC than DC tho.
Possibly the acceleration at higher speeds is more on AC because the AC system can deliver more power. Low speed acceleration is always going to be worse on 319s than 323s, simply a matter of having 1/4 of axles powered compared with 2/3.
Also 319s are geared for 100 mph outer suburban work. Porterbrook have discussed re-gearing for 75 mph max speed, which would improve the acceleration, and/or replacing the traction package.
319s is 100mph top speed and is used on MML Fast Lines.
Just a small thing AM9, 323s are 90mph units though Im sure they would easily do 100 if they were allowed!
Probably more to do with 323s having power to weight figure of 13 hp/tonne compared with the 319s 9.48 hp/tonne. Low/medium speed acceleration will also be helped by 75mph gearing vs 100mph.
However much power is available, the maximum acceleration at low speeds is always going to be limited by the proportion of weight on motored axles and by the available adhesion. I do agree power and gearing will come into play at higher speeds.
I agree that I've not heard issues about using 319s on Airport-Piccadilly services. The concern is more on services via Stockport and Guide Bridge.
Services stopping at Heaton Chapel and Levenshulme do cause massive problems if they are timed for a 323 and not operated as such. The xx:38 Piccadilly-Alderley Edge runs the bare minimum amount of time ahead of the xx:52 Liverpool-Norwich between Slade Lane Junction and Heaton Norris Junction.
Another example further down the WCML is the 17:09 Deansgate-Stoke can't be more than 2.5 minutes behind schedule between Macclesfield and Stoke or 17:35 Piccadilly-London service catches it up.
The 319s can do over 110mph. Just not rated for it.
So does that mean that their motors' balancing speeds have been set too high with the gearing. If so, then operational performance has been thrown away for over 25 years!
As Chat Moss is now a 90 mph railway except around Astley what is the point of having a 75 mph maximum speed?
Also reducing the units to three car would on some services reduce capacity as quite a number of services are already booked for 2 x 2 car units.
....Also reducing the units to three car would on some services reduce capacity as quite a number of services are already booked for 2 x 2 car units.
Hitachi are building a three car demonstrator to come to the UK next year and be lent out to TOC's for evaluation. I think the length is highly suggestive of geographically where they are targeting for potential orders, if they had been targeting orders for Southern tocs it would probably have been a 4 car unit.
Next year they will be running in DMU times anyway, because there won't be enough to fully convert any one service.
I pass on FCC's a fair bit... I don't think 319s acceleration is that poor. In the real world anyway and not just on paper... The brakes do seem to be v.good on 319s (unless is wet)
