Northern rolling stock changes post electrification
8J
31 Aug 2009
No they don't. Sprinters and Pacers have a BSI coupling whereas 319's are tightlock...
61653 HTAFC
18 Dec 2012
Speaking of coupling compatibility, AIUI 323s were specified to be capable of multiple working with 317-322, but has this ever been done? Either in Manchester or Birmingham?
Domh245
6 Apr 2013
nowhere
Here's an idea: are 319s coupling compatible with 150s or Pacers? They both have tightlock coupling heads, the couplers are all in the same spot...
No they aren't. The 319s have tightlock, the DMUs have got BSI couplers, and even if mechanically they were the same, the electrical connections almost certainly wouldn't be!
fowler9
29 Oct 2013
There seemed to be a large number of 319's on Allerton when I passed through at 17:00 this evening. I was a little surprised at that, appeared to be 4 there. My Preston service which I caught to Lime Street was a 319 though.
I almost forgot, on Monday the same Parkway to Preston service was kicking everyone off at Lime Street to change unit, I didn't see what went forward to Preston.
familyguy99
22 Jun 2011
Oldham
Not too sure where to put this but I notice the is Class 319 park up on platform 6 at Manchester Victoria today which seen unusual but with engineering work taking place at Victoria station I guess this train couldn't gone back to Allerton depot or even to Victoria sliding if work is taking place around there.
175001
3 Feb 2007
Between Heaven and Hell
Full possession both ends at Victoria today, no access to Turnback sidings either due to the possession. And Network Rail have a fascination of keeping Plat 3 at Victoria clear
childwallblues
3 Jul 2014
Liverpool, UK
And I took the 0912 LIV-NCL to MCV today and it unusually arrived at Platform 5.
DJH1971
10 Jun 2012
St Helens, Merseyside
There still appears to be a spate of 319 failures at Northern.
Yesterday the 08:25 service from St Helens Junction to Liverpool was a 156 and this morning, the 07:38 MCV to LIV was also a 156.
So much for Northern going electric then.
northwichcat
23 Jan 2009
Northwich
Well I've never been on a 150 that has failed while I've been on the train in 31 years and I've only been on 2 x 142s which have failed while I've been on the train in just under that time, despite regularly travelling on both types of units.
I knew after posting that I'll be on a 150 that breaks down and last night I was on a 150+142 combination which failed after stopping at a red signal.
50032
3 Mar 2016
158722 said:
One of the magazines this month is quoting an extra 12 319s for Northern - first time I've seen indication of a number for the extra units.
Where will these be used.
It looks like only Preston will be wired by December 2017 and as things stand the only service that could go over to electric traction is the Hazel Grove - Preston if it doesn't continue to Blackpool.
As well as Preston to Hazel Grove electric services from December 2017, I have read that the Piccadilly to Crewe via MIA services will become Liverpool - Chat Moss - MIA - Crewe services, serving all stops along the Styal line in the timetable re-cast. So perhaps the Piccadilly - Crewe via Stockport services will run out and back via that same route, and the via MIA services will convert to 319 traction. I can't see 323's running over Chat Moss for the short time they remain in the north, due to lack of train crew competency.
Whistler40145
30 Apr 2010
Lancashire
Yeah, if 323s are off elsewhere, why put them on the Chat Moss route, 319s will be sufficient for the time being.
Also, no point putting 319s on the Piccadilly to Stoke services.
Iskra
11 Jun 2014
West Riding
So they are going to be fitted with GWML AWS etc. just because they were made by Siemens/CAF and look the same from the front?
That's what a Northern Guard who was working one told me yesterday morning. There is absolutely no need to be so patronising.
Iskra
11 Jun 2014
West Riding
What's going to replace them on Northern ?
Arriva's new stock or maybe 319's, I'm guessing. There has already been discussion of six-car formations on the Aire Valley, the only way that could realistically happen would be 2x3 car EMU's.
I'm not advocating 333's to Heathrow Express, just reporting what I was told yesterday. It would of course be a great shame for Northern's newest rolling stock to be sent South.
Greybeard33
18 Feb 2012
Greater Manchester
But according to the Northern franchise agreement, Northern will only operate 4tph between Piccadilly and the Airport between Dec 2017 and Dec 2019. These have to include the Blackpool North Northern Connect service remapped from TPE; a new Liverpool semi-fast Northern Connect DMU service on the CLC line, which replaces the current 319-operated semi-fast on the Chat Moss; a new Northern Connect semi-fast DMU service to Barrow/Windermere via the Chat Moss; and a Liverpool stopper on the Chat Moss, which replaces the current 319-operated Liverpool-Victoria service. The Piccadilly-Airport shuttle, currently 319-operated, will therefore be scrapped and one of the Connect services (most likely the EMU-operated Blackpool?) will have to call at all stations between Piccadilly and the Airport instead.
So if the Liverpool-Airport Chat Moss stopper is extended to Crewe, it will effectively be formed by joining the current Liverpool-Manchester 319 stopper to the current 323 Manchester-Crewe via Airport service. But 319s will no longer be required for the two services they currently operate to the Airport.
Northern does not start to get its new trains until 2018, so I guess 319s might temporarily be used on the Airport-Blackpool North service, once the wires to Blackpool are up.
50032
3 Mar 2016
I understand there'll only be 4tph from December 2017, and that the Southport and Picc-Airport stopper will go. But I'm curious as to what'll happen to the Picc to Crewe via MIA. It could combine with the Liverpool - MIA service, as suggested earlier, but that would mean 319s working to Crewe. Or could the Crewe still run Styal line but omit MIA? However I'd assume there is a requirement to run something between MIA and Wilmslow (& onward stations).
Philip
27 May 2007
Manchester
There's an issue about running 319s to Crewe because of the slower acceleration of the units, compared to 323s, meaning the service may have to be re-timed and slowed down.
The other possibility could be running the Blackpool-Airport service onwards to Crewe, using 185s, which would keep to timings well because of their fast acceleration and top speed. I'm surprised this hasn't been mentioned, as it seems DMUs will be required to run this service beyond 2017, because of the delay in Preston-Blackpool wiring.
Greybeard33
18 Feb 2012
Greater Manchester
The TSR includes requirements for weekday southbound services that:
Fourteen services departing from Manchester to Manchester Airport shall also call at
Wilmslow and Crewe [out of 51 total to Wimslow, of which 33 have to call at Handforth and 33 continue to Crewe].
Four further services departing from Manchester to Manchester Airport shall also call at
Wilmslow. Reasonable endeavours shall be made to provide Connections with services to
Crewe, at Wilmslow.
and for northbound:
Twelve services departing from Crewe to Manchester [out of 32 total] shall also call at Manchester Airport.
One service shall be provided departing from Crewe to Manchester Airport arriving no later
than 05:15.
Eighteen services departing from Wilmslow to Manchester [out of 49 total, of which 31 have to call at Handforth] shall also call at Manchester Airport.
So this rules out any Styal line services that bypass the Airport. A few early morning/late evening Styal line services can turn back at Wilmslow or Alderley Edge instead of continuing to Crewe.
It is not specified which of the 4tph from Picc to the Airport should continue to Wilmslow/Crewe, but I doubt it would be either of the DMU services. This leaves the Liverpool stopper or the Blackpool Northern Connect - I guess the decision might be dictated by the need to make the timetables match up either side of Manchester.
I should think that a 319 ought to be able to pretty much match the 323 time between Wilmslow and Crewe, considering it could use its 100mph top speed running fast between Alderley Edge and Holmes Chapel?
Philip
27 May 2007
Manchester
Running direct semi-fasts services between Crewe and places along the Bolton corridor seems to make more sense for connection opportunities, compared to running the Liverpool stopped from Crewe.
As for the second Picc-Airport stopper, I wouldn't rule out the Barrow service just yet; in North Western and even early FTPE days the Cumbria services used to call all stops between Piccadilly and the Airport during the day.
I'm thinking...Crewe to Blackpool calling Sandbach, Wilmslow, Airport, Heald Green, Piccadilly etc... With the all stops services being the Liverpool via Chat Moss stopper and the Barrow/Windermere services.
AM9
13 May 2014
St Albans
Wasn't patronising at all. As you posted earlier, Rumours, - unless someone can think of a logical reason why 333s in particular might be deployed down south.
Greybeard33
18 Feb 2012
Greater Manchester
The Crewe to Airport service is required to call at Holmes Chapel and Alderley Edge as well as Sandbach and Wilmslow.
With 4tph TPE services and at least 1tph freight on the Airport line in addition to the 4tph Northern services, I think the second stopper might struggle to keep out the way if it is a DMU.
D365
29 Jun 2012
Contractual agreement between Yorkshire PTEs and the Northern franchise holder means the Class 333s must remain until 2020. Don't forget that Arriva is planning to replace their Class 321/322 fleet by cascading the 333s. Somehow I doubt that HAL would be willing to pay them off.
Philip
27 May 2007
Manchester
Like I say though can we be sure anything other than the Liverpool stopper will be EMU operated by Dec 2017? The only new section of electrified track by that point looks like being Manchester-Preston, with the Blackpool completion date being unclear atm. Of all DMUs, 185s are the best for acceleration.
