Beveridges
You come up to a question in MT4.1 that you don't know. Do you:
A) Make a wild guess, or
B) Leave it blank
If you do (A )- you might pick up a point, you might not. If you do (B) you will definetely not. Clearly A is better.
Or you notice that you are running out of time and there are many questions that you will not be able to answer in the 30 seconds that you have got left. Do you:
A) Make wild guesses on them all, or
B) Leave them blank
If you do A you will definetely pick up some points that could make the difference between a pass or a fail. If you do B then you will not pick up any extra points and you could be on your way home very quickly if you didnt answer enough correctly.
If you don't struggle with MT4.1 at all then you won't need to guess, but if you struggled with the questions like I did then the guessing is going to make a big difference.
B) Leave it blank
B) Leave them blank
