Northern Rail Complementary Pass Routes - lancaster to hull?
mickulty
8 Oct 2016
I have one of those "free single journey anywhere on the Northern network" delay repay tickets, and at the risk of asking a stupid question wanted to double-check that my journey plans are kosher.
I'm looking to travel from Lancaster to Hull. I figure the first leg will be Lancaster to Leeds, then from looking at the journey planner it seems the next hop is Leeds to Selby before finally getting a train from Selby to Hull
I have two questions:
1) Is this actually the most sensible route, given the restriction to Northern services? I'm not especially familiar with anything north-east of Manchester.
2) Is this within the definition of a single journey for the complimentary travel pass?
I realise the answer is probably "of course it is" to both, but a second opinion will help put my mind at ease.
Many thanks for your time.
Merseysider
Fares Advisor
22 Jan 2014
1. Try fastjp.com. It can show the fastest routes, such as changing at Preston and York.
2. Yes. Any station served by Northern to any other station served by Northern. Provided the route you take is reasonable you'll be fine.
I am not sure as I do not know your intended departure time or travel date.
See: http://www.fastjp.com/#journeys?ori...170913&otime=1000&maxres=20&maxch=10&extra=on for Northern only itineraries. Change the date & time to suit your needs. You can add via points if you wish.
I do not see how it could possibly fall outside such a definition.
roversfan2001
19 Feb 2016
Lancashire
The answer to question 2 is yes.
To question 1; there are 2 (or at a push, 3) routes you could take. The first is the one you mention in your post. The second involves going via Preston, Burnley and Leeds (with changes at Preston and Leeds). The slightly unusual one is via Manchester and Leeds, either via Hebden Bridge or Huddersfield. A 'normal' ticket is routed "Any Permitted" and is set by TPE so is presumably valid via Manchester and Leeds anyway; though I'm not sure whether routeing is an issue on the Northern special tickets anyway.
Using FastJP (http://www.fastjp.com/#home), the fastest Northern only journey opportunities involve a change at Preston and York; or Leeds and Doncaster.
EDIT: Beaten to it, by quite some time. :lol: Teaches me not to cram every single detail in one post.
mickulty
8 Oct 2016
Much appreciated everyone, thanks. Travel time is still up in the air but looks like however it turns out I can use FastJP. I really appreciate the reassurance as well.
