We all know expansion of Heathrow is on hold for now, but even so, improved links to the airport are necessary. Enter in my idea for a Northern rail access to Heathrow. This would allow trains from the WCML to access the airport, as well as provide a connections between communities that mainly have to rely on the M25. The section between Watford Junction and Croxley would use a reinstated Croxley rail link (although in this instance, Watford Met would remain open), before crossing the Metropolitan mainline and heading southwards on a new alignment to the GWML. The final bit would reuse the disused Poyle branch before linking up with WRATH and SRATH at Heathrow T5.
With this route (shown in red) and SRATH (shown in yellow) combined, you would essentially have one quarter of an M25 railway equivalent. There may even be the possibility of running trains from Woking to Watford via a reversal at Heathrow or a new chord bypassing the airport (not shown on map) which would help reduce traffic on its most congested section. Finally, I have added a chord to allow trains to run direct between Heathrow terminals 5 and 4 as the latter would probably be a better place to terminate some trains.
Thoughts?
Thoughts?
