Northern Heights problem
Jubilee191
12 Nov 2006
I can't seem to get the northern heights working with the LT1995 stock.
I try to load up the route, and then it says train not found. So I tried installing the train in a different place, but it still doesn't help?
Anyone having the same problem who knows how to fix it?
Cheers
J191
westcoaster
4 Dec 2006
DTOS A or B
when you get the selected route to drive click on it
i.e high barnet
with the right button and open with notepad after a few lines it should show what train you will be driving?
delete and in put what you want to drive and save.
or go through your programopen bve4
left click on the route you want
click on explore
should give you a long list
click on trains and the list of trains you have is there
write down the train you want (on a bit of paper) then copy the steps at the top of the post
thats how i get it to work
good luck
LabRatAndy
4 Jun 2006
The Northern Heights route needs to have the Northern Line Route installed as well.
The LT1995 stock should be installed in the Train Directory of the main BVE directory ie. C:\Program files\makcoy\BVE4\Train as this is where BVE will look for the train when it loads it.
Hope this helps
Jubilee191
12 Nov 2006
nope it still says train not found, and I have northern line v3.1 installed and it finds the train perfectly...
Jubilee191
12 Nov 2006
what do you mean tom?westcoaster's method didn't work either, there's no list for trains when you explore, and the LT1995 is already there and it's the train I want to drive...
T
Tom
Guest
Re-run the install and make sure the install directory is *correct*
Jubilee191
12 Nov 2006
C:\Program Files\mackoy\BVE4\Train
It's inside train, but it's also here
C:\Program Files\mackoy\BVE4\route\railway\Object\NH v2\Train
And I don't know how it got to that second path...
Hope this helps
J191
LondonBVE
22 Dec 2005
Lost!
Try installing the route to the correct folder as listed below:
The installer is a 3 in 1 installer, which means it includes the sound, objects and route, so you just have to install it to C:\Program Files\mackoy\BVE4 and it will works.
Coxster
9 Jun 2005
You have installed the route to:
You should have installed the route to:
C:\Program Files\mackoy\BVE4\railway where the sounds/route files/objects go in the respective folders. The train should therefore be in C:\Program Files\mackoy\BVE4\Train
