Northern England W12 Upgrades Pipeline
Legolash2o
27 Sep 2018
Previously, I posted about Loading Gauge upgrades associated with the Transpennine Route Upgrade (here), which came via an FOI request.
Within the FOI they mentioned a separate W12 upgrade project. The response from that FOI indicated the results below, but please take these with a pinch of salt as the routes are still in the design phase.
EDIT: An estimated timeline for these to be completed is December 2033.
LORELRFromTo
LN854NOCColton JnChurch Fenton
LN902CFMChurch FentonMicklefield
LN898HUL3/4MicklefieldLeeds
W12 Upgrade Project
LORELRFromTo
LN854NOCChurch FentonAltofts Jn
LN804MGWGasgoigne WoodMilford Jn
LN874MEW2Whitwood JnMethley Jn
LN898HUL1SelbyHull Port
NW6005MVE1Manchester VictoriaDeal Street Jn
NW5015 NW5021SAJ HAJStalybridgeArdwick Jn
LN842 LN846CJSAdwick JnApplehurst Jn
LN804 LN854NOC SMJ2Pontefract East JnSherburn Jn
NW2015DSENewton-le-WillowsTuebrook Sidings
NW2027SCT1Tuebrook SidingsPort of Liverpool
LN882 LN854MVN2 WAG1Thornhill LNW JnCalder Bridge Jn
GRALISTAIR
11 Apr 2012
Preston Lancs
I love the information but a better thread title might be appropriate. Transpennine route upgrade is usually considered Manchester to York. There is way more here. Possibly North of England W12 upgrades?
Legolash2o
27 Sep 2018
I agree. I've changed the title to something more appropriate.
I'm hoping they add in additional routes such as the Calder route (via Todmorden/Rochdale) to give an option to divert freight around the main corridor avoiding Huddersfield.
Looks like a plan for a W12 route from Liverpool Port to Hull Port, using the TRU route over the Pennines as far as Ravensthorpe (Thornhill LNW Jn).
What isn't clear is the route from Thornhill eastwards, as Altofts Jn-Castleford-Church Fenton is apparently not in the W12 project - maybe it is already cleared?
Either way, the W12 route will not be electrified east of Thornhill.
Northampton
The case for intervening purely for freight is sketchy enough on it's own, I'd be very surprised if there was room to include a diversionary route.
If the freight enhancement was related to releasing passenger capacity/speeding up passenger journeys, then the case becomes a lot better.
TLDR - The only way I can see Calder Valley getting cleared for W12 is if it gets electrified for passengers (which, IMO, it should).
I suspect it's more a plan for a W12 route from Liverpool to West Yorkshire and a route from Manchester to Hull/Immingham that happens to overlap, there is unlikely to be much container transhipping from port to port in the UK. Liverpool is a reaonably big player in the UK (1.7m TEU/yr in 2023) container market but Grimsby/Immingham and Hull combined are less than 500,000 TEU per year.
Here's a screenshot of PORT0301.
Legolash2o
27 Sep 2018
I think you're right and I also don't see that there would be much on the Hull port side, but there is the planned Logistics Hub at Gascoigne Wood that's going to be built, so it would open up more container opportunities for them. I am, admittedly, a believer of "build it and they will come" when it comes to national infrastructure (road, rail, broadband, etc) - but not always.
It also depends on what interventions are required. Back in early 2019, I did a FOI request about what interventions are required for the Hull to Selby line to be W10/12 (screenshot below in case you're curious). It was:
  • Move a few signals (been re-signalling since)
  • Coper Relocation at Ferriby and Howden
  • Track Slew at a few stations
  • Moving a sign
Doubtfully, but I hope, it's similar solutions for the other routes. My fear is that rail typically decide to throw everything and the kitchen sink into projects. A simple gauge project that requires a few tweaks here or there can quickly turn into massive projects with line speed increases, level crossing closures, platform extensions, additional loops, and other upgrades - costing a huge fortune.
It's worth noting that they do use new gauging techniques since the original request that makes it less restrictive.
P.S. Looking at the Liverpool statistics is bringing back a lot of nostalgia when I had to work with that data! :D
I'll do a screenshot showing the existing W12 capability in the region and highlight on it the routes from the list above. Hopefully that helps.
Northampton
It will depend on the route.
Working professionally with rail projects, the opposite is more likely to be the case. The budgets are under extreme pressure, you have to work hard to demonstrate any change is more cost-efficient (note this does not always mean cheaper). Ultimately, any change on the railway involves a lot of knock-on effects and there's not really such thing as a 'simple' project.
Be careful to keep the distinction between a programme of connected projects, one project that grows very big, and multiple separate projects in the same area co-ordinating for various efficiencies.
hwl
5 Feb 2012
LORELRFromTo
W12 Upgrade Project
LORELRFromTo
I fear there is some wishful extrapolation from your reading of the FOI response, the key text in the FOI responses before the table is this:
"The below table provides further info on whether the named section is part of this TRU W12 gauge project or not."
LOR
ELR
From
To
Is it Within TRU?
Part of W12 Project?
LN854
NOC
Colton JunctionChurch FentonYesYes
LN854
NOC
Church Fenton
Altofts Junction
NoNo
LN874
MEW2
Whitwood Junction
Methley Junction
YesNo
LN902
CFM
Church Fenton
Micklefield
YesNo
LN804
MGW
Gasgoigne Wood
Milford Junction
NoYes
LN898
HUL3/4
Micklefield
YesNo
LN898
HUL1
Hull
Selby
NoYes
TRU upgrades don't necessarily include clearing to W12 by default unless explicitly stated, the core passenger route upgrade section where W12 are stated aims are:
1. Manchester Victoria - Ravensthorpe "The TransPennine Route Upgrade (TRU) Programme’s Freight requirement is to provide W12 gauge clearance between Manchester Victoria to Ravensthorpe only. In addition, the Freight Benefits realisation project is looking to achieve W12 gauge clearance outside the TRU programme extents, to compliment the gauge clearance work between Manchester Victoria and Ravensthorpe."
2. Colton Jn - Church Fenton (1st row of the table above and the first row of your TRU table)
Ravensthorpe - Leeds and Leeds - Colton Jn aren't included because the intention is route freight away from Leeds station. (Hint: Don't bother following up on this bit in any future FoI)
The main addition needing W12 to make Man Vic to Ravensthorpe usable is Thornhill LNW Jn to Calder Bridge and Turners Lane Junctions in Wakefield via Healey Mills (the last row of you W12 Project table). This is they key part of the separate W12 project but you didn't ask about it!!! This provides Doncaster, Sheffield and Immingham area W12 routing to / from WCML via Manchester Victoria and with a short section of W10 it is otherwise W12 to Liverpool Docks
Selby - Hull doesn't need to much work to get to W12 (i.e. pretty cheap) and it connects Hull to the ECML North and Southbound but doesn't do anything for W12 on the East West Axis across the Pennines to/from Hull.
That just leaves some gaps between Wakefield Euro Terminal (your use of Altofts Jn may have caused some confusion as W12 has to go beyond to get into Euroterminal) / Methley Jn (only useful for Leeds Freightliner terminal from the North or Hull); both are already W12 accessible from the Doncaster / Sheffield / Immingham directions and Church Fenton.
Sherburn - Colton should be another section but Euroterminal / Methley Jn - Sherburn looks to have few expensive problems (bridges and tunnels) compared other sections.
(Methley Jn -Whitacre has no overhead structures so should be to bad but is pointless unless north of Whitacre Jn is done which will be expensive.)
Whitwood Junction to Methley Junction is "included in the TRU" as it got some TLC to serves as a passenger diversionary route when the normal route through Neville Hill is closed.
