Northern Dec 2022 Manchester area Timetable Consultation
scrapy
15 Dec 2008
Being run down to justify tramification perhaps.
How come all of these missing services if enough rolling stock is available (as was promised upon all the withdrawals)?
Does seem to be to save a diagram, 3 unit diagrams required to run the service half hourly this uses 2, be that because of a shortage of train crew or rolling stock, nothing to do with pathing or capacity.
sonic2009
19 Jan 2010
Crewe
But the peak extras between Stockport and Chester are restored.
I've seen that, I don't live along the line, but the comments I've seen on social media over the past couple of years...
This probably is for another thread, but Northern really need not to send 156+150 down the Mid-cheshire as they don't fit on the platforms.
Starmill
18 May 2012
Bolton
I think Widnes is a victim of the decision to remove the second off peak stopping service between Manchester and Warrington. Urmston and Irlam stay at 2tph. I meant to include it in my list, it's the same at Birchwood.
Warrington West is similar, only 1tph to Manchester and it's exceptionally slow.
More about running them across Warrington, I think?
This is why I wonder if it is an error. It doesn't seem to be a service designed for 2 diagrams, it seems to be a service designed for 3 with one missing.
janb
16 Jul 2008
I think that this was planned in the form of a 2310 Manchester Airport to Carlisle service which formed the first Liverpool bound train the next day. Presumably such ideas are in the bin now as nobody wants to pay for them.
They did introduce the 2310 Manchester Airport - Carlisle in December 2019 but without the Lancaster stop, I presume because Avanti would have had to keep the station open longer, staff employed later which I guess would have been a stumbling block.
Changing the last Piccadilly to Lancaster from 2225 to 2150 puts us back to the old days of pretty much a guaranteed hotel if you want to go to "evening things" in Manchester.
Yes, it's very poor. They really should look to see if it can be pushed half an hour or so later like it used to be. I don't know if they've worked out the shifts and that saves a considerable sum, though.
Hopefully the local Press in Lancaster and Barrow pick it up and push the point - surely they should be louder than OPSTA? (Not that the Southport thing really affects this one) - if you actually live there (rather than just having noticed it as I do) perhaps it would be good to bring it to their attention.
jfollows
26 Feb 2011
Wilmslow
It doesn't show all operators, but shows some of the others such as TfW, but not Avanti or Cross Country. That's OK.
The main thing for me is that my local service reverts to the pre-2018 timetable and, as already said, services terminate in the main Piccadilly station. In a way the post-2018 timetable has just about got to within a semblance of working nowadays, excepting the reliability of the 769s. Oh well.
I "might" have just tipped off the Lancaster Guardian and Barrow Evening Mail about the earlier last train from Manchester, let's see if that can get them some consultation responses :)
Hopefully it does. Last trains at a decent hour are the Canary in the coalmine for the "crumbling edge".
scrapy
15 Dec 2008
  • Drop in frequency for Buckshaw Parkway and Horwich Parkway, although Horwich has some peak extra calls on the Barrow/Windermere services. Will these services be strengthened? 3 carriages could become a squeeze on those Cumbrian services now routed via Bolton. The current 3rd hourly service is down to 2-hourly currently and was closely timetabled to the main Blackpool services, so overall not a great loss especially with 6-car Class 331s running throughout the day now.
Unlikely to be strengthening on the Barrow/Windermere due to platform lengths, although running 2*2 car 195s on some Barrow services is being investigated.
Should also be noted that the Blackpool to Manchester services (and Liverpool to Blackpool/Wigan) expected to revert to 4 car 331s from December 2022 so that will be a capacity loss also. (The 3 car units will be swapped back to Leeds area to run as 6 cars there once capacity at Leeds allows).
It is actually possible to run 6 car to Barrow, but you have to lock up the back unit north of Carnforth. I've seen it done in TPE days.
4 car to Barrow is certainly doable to Barrow with all coaches in use, I've also seen that, might require local door at some of the smaller stations.
I think I've seen 4 to Windermere before, too (double 156), but it might similarly require local door at intermediates.
Greybeard33
18 Feb 2012
Greater Manchester
Under the original Option B (or C) proposals, I believe that Trafford Park, Humphrey Park, Chassen Road and Glazebrook would all have got 1tph, Widnes would have retained 3tph, while Halewood and Hunt's Cross would have had 2tph. But the Oxford Road stopper (1tph) would have terminated at Warrington Central instead of running through to Lime Street, with 2tph stoppers from Lime Street also terminating at Warrington Central.
The change in Option B+ is because of the consultation responses, supported by TfN, that demanded retention of cross-Warrington services, especially direct trains from Warrington West to Padgate, Birchwood and Manchester. The through stopper has to skip-stop to stay ahead of the following semi-fast.
The consequent poor service at the minor stations is an unintended consequence of the assumptions in the business case for the construction of Warrington West, which raised unrealistic expectations about the service provision that would be possible at the new station.
Moonshot
10 Nov 2013
The aspiration ought to be a minimum of a train every 30 minutes from any station. But it would take some infrastructure interventions to achieve that. Or more like a replacement of some current heavy rail lines with trams
Option C came very, very close to doing that. As did B+ in most places other than the vexatious issue of the CLC, but what Northern have put up is a lesser version of B+ with more cuts, some of them really sloppy such as a 3-diagram Rose Hill half hourly service with one diagram lopped out but nothing else changed.
Ianno87
3 May 2015
Option C fell down on a a combination of:
1. "The Southport Question"
2. Driver training requirements
3. The level crossing impacts of diverting TfW via Northwich, and
4. The Operational Cost of it, as it required quite a few increases to turnround times etc to provide a neatly structured service through Central Manchester.
2 and 3 could have been delivered with more time to do so.
td97
26 Jul 2017
Oh dear
AM peak services on Preston - Bolton - Manchester are full and standing with the 6 carriage provision today. One day several weeks ago a 319 was substituted and it was sardine style.
The corridor sees a lot of students heading to Oxford Road so is not badly affected in terms of fewer office commuters .
I hope local stakeholders will have enough clout to retain 6 carriage services west of the Pennines.
Could some of the surplus electric units (319 onwards) be formed into 3 carriage units and run in double to crowd busy the Bolton route ?
IanXC
Emeritus Moderator
18 Dec 2009
Sould also be noted that the Blackpool to Manchester services (and Liverpool to Blackpool/Wigan) expected to revert to 4 car 331s from December 2022 so that will be a capacity loss also. (The 3 car units will be swapped back to Leeds area to run as 6 cars there once capacity at Leeds allows).
Weren't the 4 cars used on Blackpool to Liverpool and Wigan to Liverpool before they went East?
I don't think it's safe to assume that Blackpool to Manchester will go to 4 cars - there's 31 3 car units and only 12 4 car ones, unless the 333s were to go I'm not even sure there's enough space in the Leeds area to even stable them all!
Ianno87
3 May 2015
Having seen the loadings on Blackpool services recently, switching to 4 cars from 6 cars would be bizarre to say the least. Very well-loaded, all day.
319s can't easily be reduced to 3 cars as there is equipment under every coach. That's why LNR's 321s were moved to Scotland with 319s replacing them - 321s can be easily shortened as one of the trailers is a "dead" trailer with no equipment required for operation.
But that's a bit moot, because you wouldn't want to replace 6 x 24m with 6 x 20m, as that's an overall reduction. You'd go to 8 x 20m.
That is interesting. I wonder if they could be lengthened to six instead !
scrapy
15 Dec 2008
There are some 6 car workings to Barrow now (mainly to move units around), however the rear set is usually locked throughout from the airport as it can easily take 5-10 minutes to lock the set out and this isn't allowed for in the timetable.
Issue with class 195 in multiple as a 4 car is there are no butterfly switches on the outside and the external crew access will not work with the drivers key in. So all passengers for Dalton and Roose would have to be in the rear set with the guard. This risks people who are not in the correct part from Ulverston being overcarried as there's no gangway between sets, and there are also accessibility issues as there is no wheelchair space (or lugs for a ramp) at the local door at the front of the rear set so it makes the train at Dalton and Roose (currently accessible)inaccessible for wheelchair users. There would likely be the same problems on the Windermere line.
Think it's 20 or 21 3 cars heading east, so that will leave 10 or 11 in the west. Thats a maximum of 5 six car diagrams (more realistically I think there would be 4) certainly not enough to cover all the Manchester to Blackpool's as at present. 323s (single units) likely to be more common on Wigan to Liverpool stoppers from Dec 22.
FManc
21 Jul 2011
From a purely selfish point of view it’s really frustrating the first trains from Hazel Grove, Davenport and Woodsmoor have been pushed back a further 17 minutes :rolleyes: It just means more driving in for our household!
geoffk
4 Aug 2010
Exeter
Although I no longer live in the area, I was pleased to see that the local stations at the Manchester end of the Calder Valley line get their half hourly service back. The Leeds - Chester has calls at Low Moor added. This was supposed to be a part-replacement for the former TPE link between Leeds and Warrington yet it's the slowest train on the CV now, all stations Leeds to Todmorden.
A few other random comments -
Didn't the Walkden line go up to 3 per hour before Covid? If so, it's back to two, with an extra in each peak.
EMR still has some peak hour stops at Chinley to cater for Stockport commuters.
The Ordsall Chord is down to one train per hour as expected, not good value for what it cost. If it's the Redcar service even the overhead wires won't be used.
Greybeard33
18 Feb 2012
Greater Manchester
I believe the 6-car 331s on the Blackpool route have to use SDO at some stations due to short platforms. That rules out older units (including Northern's 323s) that are not equipped with SDO.
AMD
6 Dec 2017
Yes, the 319s are due to be handed back to Porterbrook by the May 22 timetable change, with the West Midlands 323s backfilling diagrams.
Adlington, Blackrod (DOWN), Layton (UP) and Leyland are the problem stations. There was a proposal floating about in 2019 at getting the 323s retrofitted with some form of SDO, however that's gone really quiet - I imagine someone had a look at the potential cost!
I wouldn't be too sure on that one. Though yes, in retrospect, 1tph is a pathetic showing for a ~£100m investment.
323235
8 Dec 2007
North East Cheshire
Again, it was a bit of an outlier being so good in the first place. Probably not a surprise these things are targeted for cost cuts.
If some investors can convince the planning authority and have the money, it could be wonderful. But given that's not going to happen...
Glazebrook is very similar to Carrington, which is being taken over by new build houses. I think some level of extra development is inevitable and an eco village would be in keeping with the horticulture and nature of the area but whether is financially attractive enough is another matter.
As @yorksrob said it has some very good leisure options and there is enough demand to seemingly justify a ticket office for 3 hours in the morning on weekdays.
It isn't that far from Leigh, Lymm, Partington and Cadishead, so is a quieter railhead for these places particularly to Liverpool.
From what I've heard the 323s from West Midlands Trains are running late again due to Class 730 introduction slipping further behind. They can't count on a full compliment for May 2022.
vlad
13 May 2018
I was in a 6-car 195 from Manc to Barrow last month. On the approach to Wigan we were told that the rear 3 coaches would be detached there and so everyone would have to move to the front. (We did leave Wigan late but caught the time up fairly easily.) It was therefore surprising on arrival in Barrow when both units were still coupled together. There wasn't any obvious reason why they needed all 6 coaches south of Wigan so I'm assuming they just forgot at the airport. It's also odd they didn't change at Preston as the train was scheduled to stop for longer.
6 coaches will fit into the platform at Barrow but not at many (any?) of the other Furness Line stations. There was even one station (Dalton I think) where only one passenger door was opened.
Starmill
18 May 2012
Bolton
There are insufficient three car 331s even today, with various pieces of EMU work in the Liverpool area still withdrawn, for the Manchester Airport or Hazel Grove to Blackpool North services to all be diagrammed with pairs.
The Manchester Victoria - Preston units will be released.
It seems likely that at least one more electric unit than today will be needed to provide separate Hazel Grove diagrams, which could be a four car if available, or a pair of three car 331s if not.
So however you look at it it's very unlikely that there are enough 331s to cover 2tph Manchester Airport - Blackpool North in pairs.
However, with a small amount of work at Layton and Adlington (Lancs), and a more significant amount of work at Leyland, and putting all of the calls at Salwick back into the South Fylde, pairs of 323s would be feasible.
Regarding the Cumbria services, the net provision of three two car 195 diagrams and a driver for shunting might be all that'd be necessary for these to run as five car between Manchester Airport and Preston.
I also note that the incoming fleet would hint at a small surplus of two car class 156 and three car class 323.
