Northern Class 195: Construction/Introduction Updates
Geeves
6 Jan 2009
Rochdale
I'm going to assume when Bolton news says "coupling one unit to another" they actually mean one carriage to another. The auto couplers on the ends of the units are of a generic design found on hundreds if not thousands of different trains around the world.
td97
26 Jul 2017
TBH I wouldn't trust a local rag until someone from Northern confirms it.
Especially as it states all the trains are built in Spain, when in fact now they are being assembled in Newport. And there are 101, not 98 new trains.
Yes, that's how I read it too, which would agree with the issue that has been reported here.
YorkshireBear
23 Jul 2010
Lots of anti EU comments unsurprisingly, if the British had built them this would never ever happen we always make perfect everything!
Not yet they aren't, and all the engineering will still come from Spain.
Just as the 80x is a Japanese train whether built in Kasado, Pistoia or Newton Aycliffe.
Yes, there are some components which come from UK suppliers, but the major stuff doesn't.
That's also largely true of trains from Derby by the way.
Sleeperwaking
20 Oct 2018
I saw a video of a 195 being tested for water tightness at the Newport factory on LinkedIn the other week, so can't be far off now.
Aha - found the post eventually (link). It's mainly just a short video, with accompanying text: "First CAF Newport train in water test".
td97
26 Jul 2017
a_c_skinner
21 Jun 2013
If it was unit end couplers they'd still be testing single units, I imagaine and the description of the coupler as "too big" sound more like a fixed bar fouling the sides of (what we trainspotters call) a drag box.
Harvey B
11 Mar 2019
I mean they are a different class of train...
But technically everything being discussed here is also the same as what's being discussed in that thread and I don't think the TOPS number or the fact that one is Electric and one is diesel actually matter
Mathew S
7 Aug 2017
BREAKING NEWS
https://www.theboltonnews.co.uk/new...eet-delayed-after-engineers-discover-a-fault/
thought it was the intermediate coupler, but obviously, i was wrong.
It is the intermediate couplings that are the issue, and Northern's press statement (which I no longer have, since this happened a few weeks ago) confirms that. Not quite sure how Seamus has got the wrong end of the stick, but he's managed it.
I *think* that's a unit completed in Spain which has been put through Newport for some final tests.
None of the Northern/TPE trains were due to be assembled at Newport, although programme delays might have altered that plan.
anamyd
17 Aug 2018
I posted this; wonder if they'll take notice:
Anamyd Nawor 12th April 6:27 pm
The problem is with the internal bar couplers between each of the vehicles within a given unit, not the external (e.g. Dellner) couplers on the unit ends. The actual problem is that the housings that the internal bar couplers sit in aren't wide enough for the tight curves / bends on UK tracks. Those tracks aren't to the European TSI (Technical Specifications for Interoperability) that the trains were built to! It's a good job that this issue was caught at this stage and not after the Northern units had entered passenger service or the West Midlands Trains or Transport for Wales CAF multiple-unit train builds had started. I believe it also affects what will be the TransPennine Express units, but not the TransPennine Express or Caledonian Sleeper locomotive-hauled passenger coaches, despite being CAF-built.
Spartacus
25 Aug 2009
Most of what's CURRENTLY being discussed here might be common to 331s (and largely also 397s, and presumably forthcoming 196s), but there are a lot more factors to their introduction than one fault common between multiple fleets.
Llama
29 Apr 2014
That seems to imply that the issue is with the permanent way rather than the stock, which is contrary to what we have been told in internal communications.
LOL The Irony
29 Jul 2017
Chinatown, New York
I read it as them saying our tracks aren't the right type for their special little train, basically admitting they screwed up. Considering they helped build the 332's, I'm surprised this is an issue.
Nymanic
6 Jan 2014
Manchester
Since the 332s and 333s have 3+2 seating, I assume the carriage body is slightly wider, which might just make a difference.
It's unfortunate that the 195s and 331s weren't built to the same width, for the sake of extra standing space or future reconfiguration, although clearance issues would have probably delayed their introduction further.
LOL The Irony
29 Jul 2017
Chinatown, New York
They're 24 meter carriages so need to be narrow otherwise they'd be banned from certain routes.
Like Hitachi's issues on signalling interference, TSI conformance works both ways.
Both stock and infrastructure have to conform if that's what the train technical spec said.
