Northern class 153 livery question
mallard
12 Apr 2009
Because it's a single-car unit, so whichever way around the "swooshes" go, they'll be "wrong" when a coupled to another unit at that end...?
boeing737229
7 Apr 2017
The swooshes should face the original outer cab end of the unit, the Northern ones face the inner end
DanNCL
17 Jul 2017
County Durham
Surely it doesn't matter which way the swooshes face? It's a bi-directional unit, so the swooshes are always going to be facing the wrong way when travelling in one direction, there's nothing that can be done about that.
172212
28 May 2012
On a local stopping service near you
In the photos the OP shares, the swoosh works, as it's attached to a 158 (with a swoosh in the other direction). Does make you wonder why Northern don't couple their 153s small cab to small cab (from what I've seen) it does look a bit odd, swooshes or otherwise
Tim R-T-C
23 May 2011
How often are 153s run together? It seems to me to be a pretty rare occurrence for Northern, they are normally used as force multipliers with a two or three car unit.
61653 HTAFC
18 Dec 2012
They tend to couple them by whichever end is nearest the unit being coupled to, for obvious reasons...
I think the reason the swooshes were put at that end is because there's the blank panels (rather than windows) where the toilet is, so the swoosh isn't "lost".
xotGD
4 Feb 2017
I'm sure that passengers would rather have their train cancelled than see it roll in with a pair of 153s with mis-aligned swooshes.
IanXC
Emeritus Moderator
18 Dec 2009
I would suspect they get coupled whichever way around they happen to be when they need to be coupled.
Are you suggesting that departures should be delayed or cancelled while units are run around remote triangles to ensure that they are coupled up small cab to small cab?
