Northern Class 142 sightings
NORMAN471
4 Sep 2013
Thanks mate. I was hoping to get some mileage in 142007 today so it looks like I'm out of luck! If you see 142089, can you let me know? Ta!
142012 now in centre road having been removed from 11.30 Hull. 142030 to Cleethorpes 142094 on 12.02 Leeds.
Neptune
29 May 2018
142060 on this morning’s diesel triangle circuit. Finished on the 0831 Bradford FS - Leeds before coupling to a classmate on the 0906 to Hudds via Brighouse.
Skymonster
7 Feb 2012
A few noted today
Manchester Piccadilly
142003, 142034, 142057, 142062, 142090
Manchester Victoria
142031, 142047, 142048
Sheffield
142020, 142023, 142030, 142060, 142068
ed1971
14 Jan 2009
Wigan
142046 was back on it's home ground today. It worked the 16:37 Manchester Victoria to Wigan Wallgate service coupled to 142042.
142004 (with 150204) worked the 10:50 Wigan North Western to Alderley Edge service. 142004 has a bad wheel flat.
superkev
1 Mar 2015
west yorkshire
YorksDMU
5 Jul 2019
Beverley
I saw 142029 and 142045 arrive at Leeds at 13.55. After all passengers had detrained, the two 142’s then coupled up to two 153’s, before going ECS to, presumably, Neville Hill.
Here’s a photo’ which I took.
deltic14
13 Oct 2019
Ossett
Observed today:
142 047 on its own and 142 031 paired with 142 048 doing the Rochdale to Bolton shuttles all day
142 046 and 142 042 shuttling between Manchester Vic and Wigan (both stations) all afternoon (16:37 and 18:37 Man Vic to Wigan Wallgate)
Also noted through Salford Crescent at various times were:
142 032 with 150 120 (10:08 Wigan to Stalybridge)
142 017 with 156 424 (09:49 Alderley Edge to Wigan NW)
142 004 with 150 204 (12:49 Alderley Edge to Wigan NW)
142 090 with 150 114 (14:30 Stalybridge to Wigan NW)
142 001 on the 15:24 Wigan Wallgate to Todmorden.
142 043 on the 17:55 Todmorden to Kirkby.
marty56110
16 Nov 2019
North East
Due to the shambles with services in the North East today, 142078 worked the 17:56 to Whitby from Middlesbrough (cancelled between Newcastle and Middlesbrough) and 19:34 return.
144017+142033 2K51 0829 Leeds to Huddersfield
142063 2H54 0830 Leeds to Lancaster
158903+142011 2L01 0833 Leeds to Sheffield
142086+142007 2N01 0846 Leeds to Sheffield
144006 2A63 0852 Leeds to Knottingley
deltic14
13 Oct 2019
Ossett
Out and about today I noted the following:
142 007 and 142 086 on the 08:46 Leeds to Sheffield. They then formed the 10:25 to Scarborough although only 007 was available for passenger use.
142 011 and 158 903 were on the 10:39 Sheffield to Leeds.
142 024 was on the 09:59 Hull to Doncaster and 11:13 return.
142 014 was on the 10:59 Hull to Doncaster and 12:13 return.
142 087 was on the 12:33 Doncaster to Leeds.
142 020 was on the 13:33 Doncaster to Leeds. It then did the 14:44 to Leeds and 16:17 return. After that it went on the 18:06 to Doncaster.
142 068 was on a Lincoln to Huddersfield working which arrived at 14:39 or thereabouts. Seen returning to Lincoln at 17:38.
142 012 was on the 14:31 to Leeds and it also did the 18:31 Leeds.
142 060 was on the 16:08 Leeds to Nottingham which terminated at Sheffield.
142 027 was on the 16:35 from Doncaster.
142 013 was noted stabled centre road at Sheffield in the morning but was out working in the afternoon being seen at Meadowhall.
142 065 was seen stabled at Holbeck in the late afternoon.
