RichardAsh1981
- Joined
- 28 Oct 2017
- Messages
- 251
Yes, they have CCTV of the pantograph. The whole fleet is fitted.Is this part of OHLE monitoring of some sort?
Thank you.Yes, they have CCTV of the pantograph. The whole fleet is fitted.
Not for delay attribution purposes, but it's still useful to know exactly what's gone wrong when things do go wrong!So when GBR brings track and train back together they won’t need them?
This will all still happen, I should expect, with money moving around just as much as it does now.Not for delay attribution purposes, but it's still useful to know exactly what's gone wrong when things do go wrong!
You're probably right. Same hell, different smell!This will all still happen, I should expect, with money moving around just as much as it does now.
During the day yes, during darkness depending if the camera has been cleaned it’s a bit hit and missDo these cameras actually achieve what they are are supposed to in the majority of cases or are there many occasions when the camera is too dirty/covered in dead flies/scratched from being in contact at high speed with small bits of debris that get blown about to be effective?
Such as a broken dropper.Thanks for the replies. Sounds as if the camera is worth having even if there is room for improvement. Also, is any footage from the numerous day-to-day uneventful runs ever examined to spot problems on the OLE so that preventive action can be taken to avoid a major dewirement?
Not only that, but it also helps Network Rail for monitoring purposes too. In fact, it probably won’t be long before we see OHLE monitoring removed from the duties carried out by the NMT (if it hasn’t already), with nearly all modern electrics able to feed live data back now.Ive been told it's now a requirement of any new AC electric unit to have CCTV monitoring of pantographs. Its to prove liability when a train brings wires down whether it's the TOCs fault (pantograph fault) or network rails (overhead fault/object hanging).
