Northern’s Route With Highest % Load Factor Per Seat
ANorthernGuard
8 Oct 2010
2 156s are too long for Ashley, Mobberley (if the signal is at Danger) Plumley, Northwich (if the driver use the stop board) Greenbank, Delamere and Mouldsworth on the down direction. On the UP Mouldsworth Delamere Greenbank Ashley. With the method of Work it takes considerable time to perform long train short platform.
scrapy
15 Dec 2008
That board is in the wrong location, as even when it's a 2 car train it means passengers waiting under the shelter have to walk further down the platform.
It's in that location so the gantry signal is prominantly in the drivers view and also so the hump on the platform is in the vorrect place. You could say the signals also in the wrong location but I'm not sure where else it could easily go.
Starmill
18 May 2012
Bolton
It would probably be possible to provide a repeater at cab level and move the hump. But as that would be very tricky and expensive for not much gain...
northwichcat
23 Jan 2009
Northwich
The trains never stopped that far back before the hump was installed. When a double set is used, it means in the Chester direction the hump is lined up with the front doors on the front set but in the Manchester direction it's the front doors on the rear set. There's never any passenger information at other stations saying passengers with mobility issues wishing to alight at Northwich should board a specific carriage.
As there's now more 4 car workings using trains where it's not possible to walk from the rear carriage to the front, either the trains need replacing or the humps need replacing with raised platforms. Probably in an ideal world both would be done.
A station the size of Northwich should also really have a modern footbridge, accessible with the need to climb stairs. I'm sure I've heard it proposed that if that was done the disused platform 3 could be brought back in to service and platform 2 would be mothballed.
