Deepgreen
And fizzy drinks cans.
The reality is delays caused by DC buggering up the signalling system will routinely exceed occasional but more severe delays from a de-wirement.
Is it only fizzy drinks that cause the problem?
Is it only fizzy drinks that cause the problem?![]()
Yes, and also arcing to nearby objects/people. I think it's been discussed on here before, and you wouldn't want to raise the 3rd rail much above its existing potential for safety reasons.paulweaver said:Why can't 3rd rail be run at 25kv? Arcing with the rails/ground?
The issue of DC versus AC can be simply tested. The minutes lost per AC wire failure are enormously greater than the minutes lost per DC conductor rail failure. It should make the DC armchair converters hang their heads in shame. If there was a proper maintenance regime for the third rail,with ballast & footballs cleared from providing a current flow in wet weather, the power consumption comparisons would be favourable to third rail,specially as every DC 12 car train does not have to drag 10 tons of track bashing transformer up hill & downdale.
10 tonnes is only about 2% of the weight of a 12-car unit so not very significant. And if you're concerned about track bashing, pickup shoes are unsprung mass and transformers aren't.
How so? They have to be sprung almost by definition (and weigh virtually nothing, and don't affect the running rails).
Will you please download and read through the DC losses report.
https://www.networkrail.co.uk/WorkArea/DownloadAsset.aspx?id=30064784498
It might finally help you stop perpetuating the myth that all of the losses on the third rail network are down to a lack of what you call 'proper maintenance'.
I'll certainly agree with the report, and with you about losses due to maintenance, but they're only ever a small percentage of the losses, and I'd also argue that's largely a result of using an outdated system which ties the traction current collection system to sleepers, any maintenance to rail, sleeper or ballast has implications for the third rail - both damage and losses - in a way which OLE of any type eliminates.
That all makes high output track maintenance difficult and as a result makes track maintenance significantly more expensive. In the interests of fairness, I will add that Network Rail has recently invested in a new design of HOBC which has third rail support, that should hopefully help reduce costs over the longer term.
What I would add to the report and your comments about the lack of 'proper maintenance' is that dealing with all the instances of ballast shoulders contacting third rail, removing debris etc, would need more boots on track and more/longer possessions. The very small electrical losses you would prevent by enhanced maintenance would recoup only a tiny fraction of the total losses - in both electrical and financial terms - and would be completely overshadowed by the disruption and service reductions caused by longer possessions.
The biggest loss, and the problem you can't escape, and which can't be blamed on Network Rail's good, bad or ugly maintenance is the behaviour of electrons in a lump of pig iron. Basic physics is involved when it comes to variable losses (the P=I^2R losses) and that gets worse as stock length (and ultimately energy requirement) increases.
There's also the quite convoluted 400kV/275kV to 33kV AC to 750V DC transformer regime to feed DC, all those additional transformers - 33kV and 750V DC buzzing away, they're all causing losses too.
... So in answer, it is possible to install a 3rd rail DC system without these substantial losses, but not ideal. ...
They're not unsprung in any case - they sit between the primary suspension (that between axle and bogie) and the secondary suspension (that between the bogie and vehicle body).
Surely they are on a beam linking the axleboxes?
https://upload.wikimedia.org/wikipedia/commons/8/88/Top_contact_pickup_shoe.jpg
Even if a perfect installation reduced all of those losses to zero, there would still be the series resistance power loss which is orders of magnitude greater than the total leakage and galvanic losses.
That's drifting towards a partial re-design of the system - if DC to AC conversion isn't progressed further during the replacement life cycle of the DC feeders, then reducing losses and improving efficiency will have to be undertaken. The downside is it risks further cost which might not be recouped by reduced losses, and there's the possibility more return wiring and heavier wiring will make maintenance that tiny little bit more difficult.
I thought that was due to direction from the top bosses at the newly formed Southern Railway who had come from the LSWR who had been using the third rail system. IIRC they either wanted to save face and use their system as the superior system, or that the third rail was simply cheaper than the OHLE.
3rd rail DC must be at its practical limit of current per circuit (c.8000A) from a circuit protection standpoint anyway. Upgrading the cabling to reduce stray earth current might give a martginal increase in prospective short circuit current, but the big problem is the up to 6000A maximum draw of modern 12-car EMUs being so close to the maximum practical current that even the highest 3rd rail can sustain.
Having thousands of amps of load current also presents a safety problem: it's much harder to tell the difference between a train and a short circuit! A failure on the Tyne & Wear Metro (overhead DC system) showed how this could easily occur.GRALISTAIR said:That is a horrendous I squared R .
If you were designing a conductor rail standard entirely from scratch you might want to actually go with very low frequency AC - like down to 10Hz or similar.
THat would give you conductor rails without suffering from skin effect and you could deploy auto transformers every few hundred meters.
At the very least you would make it polarity agnostic so that you could have a two track main line with one line at + and another at -
That is the maximum demand that a section might satisfy. But of course, trains not only accelerate, they also spend a lot of time coasting or, these days, even return power to the network when braking, so the losses are proportional to the power actually used.
It is insanely dangerous, and only allowed because of grandfather rights. You would never get approval these days for a self-contained and similarly widescale new system which worked like that. If you had to have rail-level electrification it would be a DLR-style bottom contact system.XDM said:An unshielded 800v conductor inches from the ground seems a dangerous insanity to laymen.
Overhead electrification must be safer for staff to work with and for passengers to be around, as it's much harder to accidentally come into contact with it. Should you choose to, you could walk off the platform at Gatwick and form a nice path to earth from the 3rd rail. To do the same for OLE you'd need to either climb the masts or a train, which is much harder to do accidentally!XDM said:Yet our third rail DC is less dangerous than AC. The most fervent AC advocate on this thread promised to come back with the stats proving DC killed more than AC,adjusted for pop density etc. He never came back. He couldn't as there is no evidence,just hearsay.. So it is no more dangerous
AC or DC, you're still pushing a brick on rails at reasonably high speed. The added drag of a pantograph and weight of transformers (10 tons on top of 100s of tons) will be quite small by comparison.XDM said:True, DC faces the inevitable heat losses due to ohm's law. But these are reduced through the lower weight of DC trains,& a better aerodynamic profile,both of which reduce the demand for IxV. Three rail born AC transformers per AC train designed to withstand the shock of rail bounce are ten times more expensive per kW than static transformers that sit on a level concrete floor in a DC substation.
Quite possibly, but only because surrounding networks are also DC. Given how easy it is to make a dual voltage EMU however, it may not be a problem these days to infill with AC. There are other considerations too, such as the location of substations and availability of power from the grid. Perhaps the NDL has few locations for such substations, which combined with a historic lack of dual voltage EMUs in a largely DC-only region is why it has never been electrified?XDM said:With limited cash DC infill is a no brainer.
It is not. Third rail DC appears to be,but going through recent yearly safety reports demonstrate it safer than AC. A poster who claimed he could show DC killed more than ac(Adjusted for pop density & mileage) never came back with the evidence,although he continued his stream of postings. The evidence does not exist.
Remember NR is spending unbelievable amounts of our,& our childrens',money. We have a right to know it is being spent wisely. If the AC advocates win the day the north downs line will be permanently a diesel bye way because of NR's incredible AC ole costs. DC could be laid down cheaply,& power lines intersect the north downs tracks. DC,if properly maintained,has lower total cost than AC.
If AC is so safe why are all new AC territory bridges having the parapets expensively raised by a foot; for fun? DC for DC infilling is a no brainer.
Please share this information if you have it. Given the Edison Vs Tesla mindset you seem to have over DC vs AC, I wouldn't be surprised if you next start electrocuting peoples' dogs to demonstrate your point about how dangerous AC is.XDM said:It is not. Third rail DC appears to be,but going through recent yearly safety reports demonstrate it safer than AC. ... If AC is so safe why are all new AC territory bridges having the parapets expensively raised by a foot; for fun?
You're right, we should be spending money wisely. That's why we should be using the most efficient mode of power delivery to trains as possible. Given I^2 R, dropping from 25kV to 750V cranks up the current by over 30 times, meaning over 1000 times greater dissipated power for a given transmission resistance. Are you really suggesting that this, as well as the added cost of more substations, is better than the extra 10 or so tons on top of a couple of hundred for a 4 car EMU?XDM said:Remember NR is spending unbelievable amounts of our,& our childrens',money. We have a right to know it is being spent wisely. If the AC advocates win the day the north downs line will be permanently a diesel bye way because of NR's incredible AC ole costs.
Again, 3rd rail will only be viable if you can actually deliver the power at the correct feeder points. The lower efficiency of our 3rd rail systems means we need more substations. If it was so easy, why has it not been done already? Consider the power restrictions in place for the Weymouth electrification in the 1980s, caused by a lack of suitable feeder points, which still pose problems even to this day.XDM said:If the AC advocates win the day the north downs line will be permanently a diesel bye way because of NR's incredible AC ole costs. DC could be laid down cheaply,& power lines intersect the north downs tracks. DC,if properly maintained,has lower total cost than AC. ... DC for DC infilling is a no brainer.
For a train heading onto the North Downs Line at the Reading end from Basingstoke, would it need to reverse at Reading?
Had the Southern gone for the 6.25kV system we might have ended up standardising on German-style 16Hz electrification across the network...
ORRs most significant concern in regard to legacy third rail systems (the legacy network) is the running of bare, live conductors through publicly accessible areas. These conductors are not insulated or shrouded. The legacy network does not allow quick, secure isolations, and exposes individuals to a range of risks whilst carrying out isolations (1). Due to the difficulty in obtaining isolations on the legacy network, a lot
of work tends to be carried out on or near the live conductor, further undermining safety and weakening compliance with the applicable legislation. This is not an abstract or theoretical risk: the harm done to both workers and members of the public by the legacy network occurs significantly more frequently than on the overhead AC network (2). A duty holder proposing the laying of new bare third rail (as used across the legacy network) would therefore have to make a compelling case that it had
considered all other possibilities and could satisfactorily demonstrate that all such possibilities would be grossly disproportionate in comparison to using third rail.
(1) This weakness has been recognised by Network Rail in its acknowledgment of the safety benefits of DC Electrical
Power Asset Policy December 2012 (page 284) and is why ORR has agreed to a ring fenced fund for safer, faster isolations in CP5.
(2) This is borne out by data from RSSBs safety risk model despite the legacy network being only half the size of the AC network (4400km compared to 8200km), it contributes almost eight times more (in terms of fatalities and weighted injuries per year) to overall risks on the railway. See FWI comparative data for OLE / conductor rail / non-electrified: Network Rail Electrical Power Asset Policy December 2012 (Table 2.1, page 52).
Correct me if I'm wrong, but don't Southern's fleet of 377s carry a lump of concrete in lieu of a transformer, so there is actually no mass saving. Does this also apply to other modern 3rd rail EMUs?
