Non-Urgent TOPS Requests
kemal
5 Dec 2018
Morning
May I have the allocations for 507007, 507008, 507009, 507010, 507013, 507016 and 507001 today please?
Thank you
ls2270
24 Oct 2012
Basingstoke
Morning
Thank you
Morning,
507008 is working:
2S06 0721 Hunts X - Southport
2U13 0841 Southport- Hunts X
2S16 0951 Hunts X -Southport
2U23 1111 Southport- Hunts X
2S26 1221 Hunts X - Southport
2U33 1341 Southport- Hunts X
2S36 1451 Hunts X - Southport
2U43 1611 Southport- Hunts X
2S47 1721 Hunts X - Southport
2U53 1841 Southport- Hunts X
2S57 1951 Hunts X - Southport
2U63 2111 Southport- Hunts X
2S67 2221 Hunts X - Southport
5D68 2343 Southport- Kirkdale Depot
507009 is working:
2O03 0720 Liverpool C - Ormskirk
2G25 0812 Ormskirk- Liverpool C
2O06 0850 Liverpool C - Ormskirk
2G28 0942 Ormskirk- Liverpool C
2O09 1020 Liverpool C - Ormskirk
2G31 1112 Ormskirk- Liverpool C
2O12 1150 Liverpool C - Ormskirk
2G34 1242 Ormskirk- Liverpool C
2O15 1320 Liverpool C - Ormskirk
2G37 1412 Ormskirk- Liverpool C
2O18 1450 Liverpool C - Ormskirk
2G40 1542 Ormskirk- Liverpool C
2O21 1620 Liverpool C - Ormskirk
2G43 1712 Ormskirk- Liverpool C
2O24 1750 Liverpool C - Ormskirk
2G46 1842 Ormskirk- Liverpool C
2O27 1920 Liverpool C -
Ormskirk
5D27 2000 Ormskirk- Kirkdale Depot
507013 is working the 23 minutes past each hour departures from New Brighton every hour until 2323.
PilningRich
6 Jun 2021
Almondsbury
Morning, can anyone help with loco on this mornings 6B02 01.08 Southall TC - Cardiff Tidal. Usually then works the 6C02 Cardiff Docks - Avonmouth.
Much thanks.
kemal
5 Dec 2018
Morning
Any allocations for 507001, 507002, 507003, 507004, 507007, 507010 and 507016 today please?
I managed to get a ride on 507008, 507009 and 507013 yesterday.
Thank you so much for your help
LA50041
20 Feb 2017
Morning
003 is on Cheter services departs 09:58 then every 2 hours (with 507012)
004 is on New Brighton sevices departing xx:53 (with 508108)
cant see the others
PilningRich
6 Jun 2021
Almondsbury
Noted this might be in wrong thread, but despite having gone crossed eyed searching and a sp*csavers appointment, can anyone confirm location of Polyfilla unit 800026..... The question was asked previously elsewhere but I cannot readily see the depot/location was given, so any help much appreciated.
Rhysdabeast
10 Apr 2020
Crewe
North Pole Depot, still awaiting transfer for repairs
alexl92
12 Oct 2014
Hope this is the right place to ask but... if I were to travel from Leeds to York on Saturday morning (to arrive in York by 10am ish) and travel back a couple of hours later, is there any chance of me getting a TPE 68 + MKV set in either direction?
Rhysdabeast
10 Apr 2020
Crewe
You could get 1E25 06:54 Liverpool LS to Scarborough in the morning but that would mean you would get to York around 9am. Later on you could get 1F72 15:34 Scarborough to Manchester Victoria which gets back to Leeds around 17:00. Given that 68's mostly do runs between York and Scarborough the options are very limited.
55002
16 Aug 2019
Ldn
Anyone with tops access got actual movements of 66783 yesterday and today. Bit confusing following it on railcam.
Can't it be pieced together from RTT?
Currently working 4E75 1752 Ratcliffe Ps Gbrf to Doncaster Down Decoy Gbrf
From yesterday morning:
4R79 1005 Doncaster Down Decoy Gbrf to Immingham H.I.T. (Gbrf)
6M81 1345 Immingham H.I.T. (Gbrf) to Ratcliffe Ps Gbrf
6E60 0200 Ratcliffe Ps Gbrf to Immingham H.I.T. (Gbrf)
6M75 1041 Immingham H.I.T. (Gbrf) to Ratcliffe Ps Gbrf
The bit that seems to be missing is what it did between working
4E75 1737 Ratcliffe Ps Gbrf to Immingham Ncb 1 (Gbrf)
on Saturday evening and running 4R79 on 25 January.
It seems that 66702, 66783 and 66785 are the current locomotives on the Ratcliffe to Immingham cycles. There were a number cancelled on Sunday.
55002
16 Aug 2019
Ldn
Railcam has 66702 on 4E60 this morning and 66783 being at Ratcliffe at 0612 and Doncaster Hexthorpe Yard at 1038 so can’t have been at Donny and on 6M75 at same time
Ah, have I got 6E60 wrong?
There is also a discrepancy in RTT with 66785 allocated to both 4R75 0900 Immingham Recep Sdgs Gbrf to Immingham H.I.T. (Gbrf) and 4R79 1005 Doncaster Down Decoy Gbrf to Immingham H.I.T. (Gbrf)
So, seems that there must be a mix up between 66783 and 66785 in the RTT reports.
66783 is shown on RTT working 4E79 0830 Ratcliffe Ps Gbrf to Doncaster Down Decoy Gbrf which would explain the Ratcliffe and Hexthorpe reports. This is shown Hexthorpe at 1003 and then no further report. So presumably it then worked 4R79 1005 Doncaster Down Decoy Gbrf to Immingham H.I.T. (Gbrf) and not therefore 66785. Does that mean 66783 actually worked 6M81 1345 Immingham H.I.T. (Gbrf) to Ratcliffe Ps Gbrf, not 66785?
I see how this is confusing as the further workings on Railcam show 66783 and 66785 all mixed up.
XCTurbostar
13 Sep 2014
Another request (sorry) any ideas which Chiltern Silver set was with 68008 and 82302 today please.
Chilternblue
3 Jan 2019
Can anyone please identify the class 701 unit on 5Q42 which passed Eastleigh on the down fast at 2051 tonight, many thanks in advance
astock5000
16 Aug 2010
Garston, Hertfordshire
Is anyone able to let me know which class 180 operated 1N92 (11:27 King's Cross - Sunderland) on Tuesday 25th please? Only just discovered I must have been mistaken when glancing at its coach numbers since I noted it down as a unit which is actually with EMR and not GC...
91130nut
12 Aug 2019
Not sure if this helps, but I saw an empty 180 running through Newcastle on Wednesday morning, 26th. I first thought it was 180101 as the leading vehicle number ended in 01 but then I noticed that the remaining vehicle numbers all ended in 05. Can anyone confirm that 180105 is indeed running around misformed ? Both 101 and 105 are GC units.
kemal
5 Dec 2018
Morning
Any allocations for 321301, 321304, 321305, 321319, 321320, 321326, 321330 today please? Chasing 321 units today.
Thank you so much
