sftfan1909
Can anyone confirm the units that worked the 0715 Charing Cross to Hastings on 6/8/21 please, many thanks in advance
375617/711/920Can anyone confirm the units that worked the 0715 Charing Cross to Hastings on 6/8/21 please, many thanks in advance
66422 66727 66758 66794 66796 66797 66799Hi, does anyone know which 66s are currently at Longport?
Thanks in advance
Sorry, meant 20 minutes earlierhttps://live.rail-record.co.uk/train/?c=R22892&d=09/08/2021 There also seems to be a working about 20 minutes later, which one will run if any?
Can't see it out.
Anyone know what is on 0Z50 06.13 Toton TMD to Westbury Down TC? Many thanks in advance!
Position 1 with 387303 387305 today reportedly387 304
Ooh ... So I might finally be lucky. Please could you remind me of the time the ecs leaves East Ham late afternoon?Position 1 with 387303 387305 today reportedly
| Location | Mileage | Arr | Dep | WTT ID |
| Shoeburyness | 07:02 | 1P13 | ||
| Fenchurch St | 40 | 08:00 | 08:08 | 1P24 |
| Shoeburyness | 80 | 09:13 | 09:21 | 5S99 |
| Shoeburyness CS | 81 | 09:26 | 16:27 | 5P65 |
| Thorpe Bay | 83 | 16:34 | 16:37 | 1P65 |
| Fenchurch St | 121 | 17:34 | 17:43 | 1P86 |
| Shoeburyness | 161 | 18:45 | 18:53 | 5S21 |
| Shoeburyness CS | 162 | 18:58 |
Thank you; hadn't realised the diagram had changed!
Location Mileage Arr Dep WTT ID Shoeburyness 07:021P13 Fenchurch St 40 08:00 08:081P24 Shoeburyness 80 09:13 09:215S99 Shoeburyness CS 81 09:26 16:275P65 Thorpe Bay 83 16:34 16:371P65 Fenchurch St 121 17:34 17:431P86 Shoeburyness 161 18:45 18:535S21 Shoeburyness CS 162 18:58
Just noticed it’s the same diagram, my bad!https://live.rail-record.co.uk/train/?c=R22892&d=09/08/2021 There also seems to be a working about 20 minutes later, which one will run if any?
0E52Can someone supply the head code for 57310 that has just worked 08:31 Derby RTC to Ely today please? Thanks
Thank you for clarifying that. It has sometimes been a different one. Much appreciated.0E52
Morning, may I have the locos that were on the following please:
Realtime Trains - 682K 0450 Barnsley to Belmont Down Yard
Realtime Trains is an independent source of live realtime running information for the Great British railway network.www.realtimetrains.co.uk
Realtime Trains - 609L 0531 Barnsley to Toton North Yard
Realtime Trains - 629L 0603 Barnsley to Toton North Yard
TIA
Could anyone please assist with the Northern unit numbers on -
5B79 Newton Heath - Wolverton
5J81 Wolverton - Newton Heath
Both ran earlier this morning
Thanks
Hi,Hi, can I please ask for what is booked to work the following services later today:
2C31 15:55 PLY PNZ
2U32 16:50 PNZ BRI
Thanks![]()
Many thanks682K was 66420 on real headcode 6Y31
609L was 66555 on real headcode 6Y32
629L was 66519 on real headcode 6Y33
Are you able to re-check please? Bloke at c2c is telling me it's in position 2, the middle and as it's pouring with rain here...No problem, it is what is in the system this morning.
OK no worries; I'll wait and see.Not at work now so no access.
It what was reported earlier. Sorry
Thank you5B79 was 150133
5J81 was 150148
