NoMorePacers plans to go pacer hunting
NoMorePacers
18 Feb 2016
Humberside
With possibly the most ironic title in history, and with the recent trip report craze, 'am planning to travel. More specifically, pacers. Want to clear the Northern pacers before they see the cutting torch. Where can I get them, apart from in the Humberside area (because I can easily get those ones).
alexf380
6 Mar 2011
Musselburgh, Scotland
As I, too, have the same goal, I shall help ye out where I can. In the North East, Pacers are the staple traction on the Darlington/Bishop Auckland-Saltburn trains. They run every 30 mins Mon-Sat between DAR and SLB (only every two hours to Bishop Auckland) and there are 6 units in use here, all Heaton allocated...hopefully! Up in Newcastle, They often frequent Metrocentre-Morpeth turns and Hexam-Nunthorpe/Middlesbrough services, although the latter may see a 156 sometimes. Can't say for sure how many diagrams there are.
In Yorkshire, Class 142s and 144s are commonly seen on the *sniggers* Penistone line between Sheffield and Huddersfield, and on the Harrogate Loop up to York. I'm sure there are other services they work but I'm not too clued up on the area.
Finally, the North West. Newton Heath has an allocation of 44 Class 142 units. These are normally used (off the top of my head)on Blackpool South-Colne (4 units) Preston-Ormskirk (1 unit), Manchester Picc. - Rose Hill Marple/New Mills Central/Sheffield (~7 units). They often show up on Man.Vic/Airport-Kirkby/Southport workings, and Blackburn/Clitheroe/Chester services alongside Sprinter units. One line to avoid if you're specifically hunting Pacers is the Buxton line, as they aren't cleared there.
Hope this helps you somewhat!
NoMorePacers
18 Feb 2016
Humberside
This will also help with my route coverage, as I can get Penistone and Harrogate done, as well as head North of York.
Blindtraveler
28 Feb 2011
A fine example gracing the Blackpool South branch yesturday on the 10:20 departure, it was a lot of fun!
GrimsbyPacer
13 Oct 2014
Grimsby
Teesside had loads of Pacers, that's where I'll go after the Humberside-South Yorkshire area been done.
Kite159
27 Jan 2014
West of Andover
Local services out of Manchester Victoria (Wigan Wallgate & beyond) & Piccadilly (Rose Hill/New Mills) tend to throw out 142s, although you do get the odd 150 & 156 thrown in for good measure
Clint
12 Feb 2011
The Adwick - Sheffield - Retford - Lincoln route has Pacers running on it most of the time.
DarloRich
Fenny Stratford
156's also turn up on Bishop Auckland services. Your best bets on the proper side of the country are the North East or the Leeds/Sheffield area.
