Nominee Pass
UniRDNGStudent
3 Sep 2024
Hello, I wanted to know if the TFL nominee pass works in Reading via Elizabeth line. If so how does it work, since you cannot use oyster card at readings station?
iphone76
6 Nov 2010
South Essex
Yes. The pass is valid to Reading on the Elizabeth Line. When I've use my pass there, I just tell the barrier staff that I've arrived on / intend to travel on that line and not GWR or SWR services.
UniRDNGStudent
3 Sep 2024
THANK YOU SOO MUCH, YOUVE SAVED ME SO MUCH CONCERNS
Also, If I take elizabeth line to reading directly, to exit the barriers do I just show them my pass?
Do I also tap in or just show staff my pass at other stations?
Dstock7080
17 Feb 2010
West London
At Reading (and Shenfield) Passes will not work the gates but are valid for travel and you need to find gateline staff for assistance.
At all other stations where the pass is valid you should use the gates by tapping in/out
UniRDNGStudent
3 Sep 2024
Thank you very much, kind sir.
boiledbeans2
15 Oct 2020
I'm quite confident it works at Shenfield. It's mainly Iver - Reading where it doesn't work, which are the contactless only, non-Oyster stations. Those are the stations where you have to show your pass as the readers are not setup for Oyster.
TFN
17 Aug 2017
My staff TfL (not nominee) worked at Shenfield, maybe it’s just nominee’s set up to be rejected?
Horizon22
Jobs & Careers
8 Sep 2019
Reading - Iver is weird because contactless only is valid for passengers but Oyster is the method of ticket vaildity for TfL staff/nominees for a TfL managed service! You have to show a member of station staff (GWR or Elizabeth line as applicable) and they’ll wave you through.
Other than Reading, the other stations you’ll need to show the pass at are: Twyford, Maidenhead, Taplow, Burnham, Slough, Langley and Iver.
Everywhere (Shenfield should be okay if relevant but there’s mixed opinions) else you can tap normally.
