Noise protocols for overnight rail services
TUC
11 Nov 2010
Walking towards Brighouse station for an overnight service, I was struck by how far away the running engine for what turned out to be the 0339 to York (which had arrived at 0330) could be heard. I was conscious that this would be all the more noticeable to nearby Brighouse residents as there are not usually stopping overnight rail services at the station, although there have been on a number of occasions in recent months due to the Transpennine Route Upgrade work, and the diversion of services from Huddersfiel.
Are there any general expectations set regarding running engines during prolonged waits at stations overnight, and are there different operational limitations depending upon the type of train?
styles
7 Dec 2014
Gwynedd
Not sure about engines, but I know they turn down the volume on the station PA system after a certain time round here. I think it remains on quiet until around 7am.
The exile
31 Mar 2010
Somerset
Not an answer to the question - but I can remember lying in bed as a kid listening to Deltics open up as they set off from Edinburgh on the southbound overnights. They would have been about 3 miles away, so I can only imagine what it must have been like in the (tgen certainly single-glazed) line side buildings.
EveningStar
11 Jan 2016
Deepest, darkest Northumberland
Somewhat similar, as a kid about two miles form the Lickey Incline ... at night the sound of 2 x class 37 working hard on a banking turn travels a long way.
Same here, as a kid I could hear Class 50s from 4 miles away (it always seemed to be a warm summer evening, but I guess that was when I was most likely to be outside!)
To answer the question - no.
trebor79
8 Mar 2018
I remember there is (or was) a sign on the chord linking Gloucester to the Bristol to Birmingham line instructing drivers to shut down engines if held at the signal.
DaveB10780
10 Sep 2015
In the 50s and 60s I lived with the tube next to my back garden. Even though visitors were very aware of the noise I filtered it out from birth. Maybe similar happens here when you are not used to it?
sh24
28 Sep 2023
Similarly could here the 22:10 Waterloo-Yeovil as the 50 blasted away from Andover.
IIRC there are a couple of locations where signage instructed crews to shut down engines during the night. Blowed if I can remember where though.
adc82140
10 May 2008
It's been quite a while since I travelled on late evening trains (far too old for that now!), but I remember on the SW Mainline, after about 11pm John Elgar got switched off and was replaced by manual almost whispered PA announcements.
Horizon22
Jobs & Careers
8 Sep 2019
To answer the wuestion - no.
Yes probably because you had windows open and were outside!
Growing up I used to live only a few miles from the M25 and there was always this continual hum. I always thought it was worse in summer, but that’s probably just misremembering as it’s actually cooler air that helps sound travel better, which seems counter-intuitive to me, but it’s what the physics says.
Railway gets more noise complaints in autumn I believe.
Comes up all the time when people are viewing properties or selling or visiting friends & family. The “how do you deal with that?” and the people who are their long-term just filter it out because it is part of the routine.
scrapy
15 Dec 2008
The restarting of an engine can be much louder than one running for a while, so I guess it's a balancing act over which is the least worse, a consistant noise over a period of time or a louder sudden noise, but overall a shorter period of noise.
stuving
26 Jan 2017
There have been persistent complaints of noise from Reading depot since before it was built. I think it was done as permitted development, replacing lineside sidings between the running lines and Cardiff Road. While the western (out of town) end adjoins fields and industry, at the town end there are houses backing onto the depot lines. And of course some the stock living there are diesels, and they work unsocial hours, and move between different servicing facilites during overnight stays.
So not a station, but it is where stock sometimes waits before starting from the station. As it was new, there was no scope for saying "it was here before you decided to come and live in that house". Its arrival is felt as the same as an operational decision to start holding stock at the station for long periods. There is one thread here; there may be more on the topic.
168lover
2 Aug 2013
Chiltern Mailine Land
Thing is restarting an engine generally means the locos compressor needs to run in order to rebuild air. 66s as well are renowned for revving their heads off on restarting in order to build their air back up
Taunton
1 Aug 2013
The most significant racket I ever heard was at Tunbridge Wells station, with two 12-car Hastings 'Thumpers' starting together in opposite directions. Four power cars each, eight in total. However did stereotype 'Disgusted of Tunbridge Wells' (let alone the station staff) manage to put up with it.
Middle of the night in London, quiet(it is sometimes), at Poplar 1980s, I heard a couple of times what was certainly a distant Sulzer under power, and put it down to a Class 47 climbing Bethnal Green bank, but later discovered it was from the other direction, a Class 33 over at Greenwich on the night newspapers down into Kent. I had been about equidistant.
Deltics for me too, from the time when they ran an overnight on the Transpennine route. I was about a mile away as the crow flies but with a big hill in between, and only found out what it was when I moved to Scotland and encountered one in the flesh.
sabanda
25 May 2025
Bournemouth
I live alongside the railway near Pokesdown and, on the quietest nights, can hear not only the hustle alarms of trains at the platform there, but also - astoundingly - the sound of Voyagers taking power out of Bournemouth station on empty stock moves to Eastleigh. They are of course much louder as they pass us! I have only once been woken, though, and this was by an engineering train.
Torfaen
8 Dec 2025
Pontypool
I think it's the effect of a temperature gradient when air closer to the ground is cooler which bends the sound waves back downwards. A similar effect to wind direction helping sound transmission - where it's the relative air speed at different heights that causes the effect.
jondr3
20 Mar 2026
Derby
TPE had to infamously withdrawl Cl68's + MK5a sets from Scarborough after numerous noise complaints about them idling late at night or early morning. Even made the BBC Look North segment a few times
CW2
7 May 2020
Crewe
I remember alighting at York from a southbound Deltic hauled overnight, cycling home a couple of miles, climbing into bed at 03:xx, then hearing the distant but unmistakable sound of my train departing York for Kings Cross. Admittedly it was a still summer night, but even so I was impressed.
The exile
31 Mar 2010
Somerset
Trees also work well as a sound-baffle - but only when in leaf!
ox_chap
7 Jun 2026
Oxfordshire
Chiltern's Class 68s are not used on the trains to Oxford. But with so many flats now built right up against the railway, and including the northern end near the bays, I've always thought the residents had a lucky escape on that one.
milooo
3 Dec 2024
Stevenage
When there are track workers opposite your house you are most certainly made aware of it.... That was certainly one sleepless night.
