Is there some advice somewhere in the routeing guide, or somewhere else that I might have missed, as to what to do when there are *no* appropriate routeing points for a journey?
Scenario: I am attempting to determine the permitted routes between Cheltenham Spa (CNM) and Ebbw Vale Parkway (EBV). Cheltenham is a routeing point. Ebbw Vale Parkway is only associated to Cardiff Central (CDF). Fares check: an Anytime Day Single on CNM-CDF is £17.90, while an Anytime Day Single CNM-EBV is £11.40. There are no other single fares in either case, and thus Cardiff fails the fares check.
If my working is correct, there are no appropriate routeing points for this journey, even though there is only one routeing point for Ebbw Vale Parkway! It is clearly valid via the shortest route - thus Cheltenham-Cardiff via Lydney and then up to Ebbw Vale - but I would like the freedom to go via Bristol Parkway on the return. If it weren't for the fares check, this would be a permitted route.
(That said, tomorrow there are engineering works; Newport-Cardiff is shut until 16:00, and the Ebbw Vale service is diverted to run to and from Newport - so is the shortest route in fact Cheltenham-Newport-Ebbw Vale, and the ticket not valid at all except for tomorrow before 16:00?!)
Any help would be gratefully appreciated!
