nissan primera
mac
15 Dec 2010
Can anyone tell me how to fit a driver's side door handle?
rail-britain
12 Aug 2007
It depends on what you are fitting that handle to...
It's amazing what you can do with a bodge-job and what can be fitted to what!
As for fitting an OE door handle to a Nissan Primera I would have thought it would be a simple process of removing the door card, unclipping the previous handle, replacing, and then refitting the door card
Ivo
8 Jan 2010
Bath (or Southend)
The Clarkson answer is the best answer! I'll check my shed! :)
Clarkson's are always either the best or the worst, as epitomised in the White Van Man Challenge and fitting a new door:
[at his best] "James, can I borrow your van?" He proceeds to drive into his own door that he intends to remove, bending it backwards.
[at his worst] The replacement falls off after he seals it with tape and fails to attach it properly.
HST Power
25 Nov 2010
To Top Gear, long may it last! :D
I still find the HGV episode hilarious.
Ivo
8 Jan 2010
Bath (or Southend)
I might go and put it on through the TG site actually.
I also quite like the Blackpool run, but that might be my analytical side coming through.
HST Power
25 Nov 2010
The Blackpool run was quite funny. Jeremy was so sure he'd conk out right next to his house but he made it the whole way!
You should like the trucking episode. I won't spoil it, but I will say, it's carnage! :D
We've got to make a TG thread!
