mikemcniven
Derailment at Newton Heath TMD affecting services in Manchester this morning. Already affected services further away with some Hazel Grove services cancelled, I presume as services trapped in the TMD. Second derailment in Manchester in 24 hours.
Edit: apparently is 150118 after been towed back from Knutsford after the incident on Sunday.
http://www.nationalrail.co.uk/service_disruptions/151978.aspx
A derailed train between Rochdale and Manchester Victoria is disrupting trains between these stations. As the train is blocking the route into the train depot, services across the network are being affected. The following alterations apply:
Trains are unable to run from Rochdale into Manchester Victoria
Services from Leeds heading to Manchester will terminate at Rochdale
Road transport is being arranged to run between Manchester Victoria and Rochdale
Disruption is expected to continue until 11:00.
Customer advice:
You can use your ticket on Metrolink between Rochdale and Manchester Victoria.
Twitter: If you would like to follow this incident on Twitter, please use #Rochdale
