Newport to Paddington 3rd October
s3an
8 Sep 2011
Anyone know why I can't find a 05.30am Newport to Paddington for 3rd October? FGW website doesn't have any engineering work.
If it isn't running any alternatives that would be cheap.
There appears to be no 05.30 Tuesday-Friday.
regards
sean
dzug2
5 Feb 2011
It appears to be running (starting in Swansea )- but sans passengers - which usually means either a charter train or empty stock
Why - pass.
Edit - there do appear to be some ill defined engineering works the previous evening mainly affecting last trains. Maybe they are causing knock on staffing problems - ie no train manager
Alternatives - travel the previous evening or check out Megabus and National Express
s3an
8 Sep 2011
I can't move my appointment in London. FGW customer services don't know, they confirm there is no engineering work, but do not know why that train is not running.
Any helpful FGW employee know what is going on?
If i turn up at 05.30am with a super off peak return and a paper timetable, will I be allowed to catch the 06.09 even though my ticket won't normally be valid?
What about the many other people affected? That is a very busy train, even on a Friday.
It is too expensive to book a hotel for the evening before and coaches won't get me there on time.
Flamingo
26 Apr 2010
I've just looked up Avantex, there is no 03.58 from Swansea (or equivelant further up the track) on 3rd Oct. I've no idea why, except the usual "Engineering Works". All I can suggest is see what Customer Services say, if they will give an easement on the 06.09 get it in writing as chances are staff will not be told.
Paul Kelly
Verified Rep - BR Fares
16 Apr 2010
Reading
It can mean different things. With FGW it seems to usually be used when reserving a path for a train that might run but probably won't, to avoid the train showing up in public-facing timetables and booking engines.
dzug2
5 Feb 2011
For whatever reason, it seems to be a ghost train for all that week - it's running normally before and after
