Newport Essex To London
leemcl210
28 Mar 2025
essex
Hi all
Hoping to get some shared opinion in regards to how to get the best value from GA into London.
I notice that unless I get a 9:40 or later service the website / App charges nearly £38 for a ticket with an off peak travel card. Even though the off peak period starts @
9:30 and on an earlier train I would be crossing the zone boundary after 9:30, just seems a deliberate way to extract the most from the customer ( what a surprise )
I’ve noticed that if you go into a mainline station then you can get a return for around £22, which does not seem so bad, I could travel into Victoria and walk to work, although usually get a tube. Would that ticket allow me to exit the London Underground at a different station as long as it’s zone one ?
Final point, I am convincing myself that the train fares on the Cambridge to Liverpool Street line are rising above other fares and that where you could once get a 9:14 train and be “off peak” it’s now considered “peak” despite there clearly being less people…
It’s all a bit of a headache and at its cheapest it’s now costing nearly £50 to get into London and to work before 10. It’s frankly already unaffordable for many, and I only use it as the cheaper fares kick in with a Network rail card.
Mcr Warrior
8 Jan 2009
Even though the off peak period starts @ 9:30
@leemcl210 . Welcome to the forum. Issue might well be, depending on where exactly you are travelling from (have you said?) that "off peak" fares aren't necessarily available if travelling on trains arriving into London Liverpool Street before 1000 on weekdays. And, usually, Network Railcard discounted tickets are only available midweek if setting off at or after 1000. What's the exact journey you're wanting to make?
leemcl210
28 Mar 2025
essex
Hi there. Thanks for coming back to me. My usual journey is Newport Essex to Liverpool Street and then tube to Westminster and reverse. Most mornings I would go via Tottenham Hale. Ideally I get the 9:14. Which hits Liverpool Street at 10:15 or Tottenham Hale @ 10:00.
Cheers
jfollows
26 Feb 2011
Wilmslow
The statement that “the off-peak period starts at 09:30” is wrong, different tickets have different restrictions.
The off-peak return & day return tickets are valid for weekday arrivals into Liverpool Street after 10:00. The super off-peak day return after 12:00.
leemcl210
28 Mar 2025
essex
Apologies. I meant the London Underground off peak. That starts @ 9:30.
Sleepy
15 Feb 2009
East Anglia
The off peak one day travelcard £36.20 is valid on the 0914 from Newport so not sure what your seeing/ have been told ?
Mcr Warrior
8 Jan 2009
I also have an Off Peak Day Travelcard from Newport (Essex) to/from London Zones 1-6 (including Westminster) as costing £36.20 and valid midweek on the 0914 departure from Newport (Essex). Can the same journey, however, be made any cheaper?
30907
You could check for split ticketing options on our (TrainSplit's) ticketing website, but as the equivalent fare to London Terminals is £30, there's little wriggle-room.
BTW there is no valid route to Victoria from Newport (Essex).
On a ticket to London Terminals, that is. A single/return to Underground Zones 1-3, or a Travelcard to Zones 1-6, would of course be valid on the Underground to Victoria.
kieron
22 Mar 2012
Connah's Quay
As you haven't given precise fares for anything or said if you buy tickets with a railcard (and, if you do, which it is), I can't explain what you've seen.
If you regularly buy a travelcard to make one journey each way on public transport, this isn't the cheapest option. An alternatives, you could buy a ticket to "London Underground Zones 1–3" or buy a ticket to Tottenham Hale and use Oyster/contactless between there and Westminster.
