New trains cab ends not painted yellow.
superalbs
Verified Rep - Superalbs Travels
3 Jul 2014
Kraków
Hard to see any arguments for either, it's clear yellow fronts aren't safer, otherwise they would all be yellow, the majority of this is personal taste and trying to find "railway" reasons for this in my opinion
Totally agree with this.
24 Nov 2019
I think you’re overlooking just how poor train headlights used to be, right up until relatively recently. Things have moved on significantly with the advent of LED lights, to the extent that modern headlights can arguably be too bright in some situations, and the standard for yellow fronts has been modified as a result.
I am from an age where you'd see a yellow front much earlier than you'd you'd notice the dim marker lights.
The high intensity headlights today, are a huge improvement.
Agreed. Consider much of the ex Southern region’s slam door EMU stock, for example, which was in service until the early-mid mid 2000s.
Meerkat
14 Jul 2018
How is it clear yellow fronts aren’t safer? I can’t see how they can not be safer than black, so the question is what the justification is for not having them - black doesn’t make the train go faster!
irish_rail
30 Oct 2013
Plymouth
Exactly. The idea that somehow a black front end is safer than a yellow front end is laughable.
XCTurbostar
13 Sep 2014
I’d prefer yellow ends and decent lights fitted for sighting purposes
Agreed.
For me, it is also about familiarity. If you were a trackside lookout and a train approached you in the distance with no lights - which one of these is the one you are expecting to see?
43066
24 Nov 2019
Because the lighting has more of an effect on visibility than the colour of the unit or loco end.
Surely you aren’t suggesting that non yellow 717s, or 345s with modern headlights, are less visible/safe than the 4EPB in my avatar?
Agreed.
If the train has no lights it’s limited to 20mph anyway.
Meerkat
14 Jul 2018
More of an effect doesn’t mean the yellow doesn’t have an effect.
Bright lights are hard to judge for speed and distance. Being able to see the yellow front aids that.
Bright lights might not be a train. Yellow front is a train.
Neptune
29 May 2018
Agreed.
The one with the black front end looks fantastic.
Islineclear3_1
24 Apr 2014
PTSO or platform depending on the weather
but when a train is approaching from far away how likely are you to actually see it before it comes close enough where it can actually be determined as a moving train?
On straight track and in good light - a fair old distance. In bad light; maybe negligible but yellow fronts were considered safe enough for decades since their introduction in the 1960s/1970s
43066
24 Nov 2019
This sounds more like an enthusiast who likes yellow fronts inventing reasons not to change them.
Modern lights are clearly visible from a mile or more away, which is less than thirty seconds’ travel at 125mph, and render the colour of the front irrelevant. If there was any proper statistical evidence that (invariably dirty) yellow fronts are safer, or that they make it easier to judge speed and distance, the change wouldn’t have been made.
Benters
7 Aug 2022
Stafford
Agreed.
The one with the yellow end. It would be the most visible from furthest away.
Meerkat
14 Jul 2018
Sure the light is visible, but just a light. Lights are notoriously hard to judge for distance and speed.
And it’s just a light, not a train.
irish_rail
30 Oct 2013
Plymouth
I agree. Lights frequently get lost in a sea of lights, especially in towns and cities at night.
Peter Mugridge
8 Apr 2010
Epsom
If it's at night, would not the yellow end be invisible anyway unless they added another light pointing down across the front of the train?
irish_rail
30 Oct 2013
Plymouth
What light there is will reflect off yellow and the yellow will be visible . However black will be completely invisible in low light.
TheHovisKid
9 Sep 2008
Heysham
Even buses joining in the act:
(A common Whack-sone-of-our-paint-on-and-turf-it-out wheeze where a recent import could be confused with the opposition. But still.....)
MarkWiles
21 Jul 2019
There is another consideration in the yellow paint debate - footpath crossings. I remember a while back I was approaching a level crossing (driving a car) on the Cambrian and noticed a flash of yellow out of the corner of my eye, which gave me warning that the crossing lights ahead were about to go off. It got me thinking about farm and foot crossings of which there are plenty around locally. Although initially introduced for trackside safety, we've had near enough 60 years of yellow bibs and yellow ends, which help trains stand out against the countryside. Lights of course are equally visible so long as the sun isn't shining directly on them, but given many modern road vehicles are fitted with retina-melting LED lighting and daytime running lights, there is some margin for confusion by an occupation or footpath crossing user whereas lights + yellow end might just add an extra recognition factor for non-railway staff using crossings. I do wonder if the new Trans Pennine Class 802 units are conspicuous at the many footpath crossings on the TPE route when seen against the dark surrounding countryside.
Given no-one ever has said "Oh I'd love to catch the train but that yellow paint looks so awful it has put me off" I personally can see no argument whatsoever for ditching yellow paint on marketing or corporate grounds. If the yellow manages to make the train more visible alongside better lights, surely the potential visibility improvements, both for staff and people legitimately crossing the track, must make implementing both the better option - especially as there is evidence of that crash in the Netherlands, which I had heard about, leading to a change to add yellow to the front of a train which was already lit up like Blackpool seafront.
vuzzeho
11 Apr 2022
I don't really care about yellow front ends. They're fine but I don't mind them. My main issue, however, is that despite operators now having the freedom to basically do whatever they want with the front ends, most operators just make them black. It's unusually boring - they could make the livery a whole wraparound job but they act like they must keep the front one block colour (that usually doesn't fit with the livery) and I don't get why.
Meerkat
14 Jul 2018
Does it hide the splattered bugs better?
