New Ticket Design Launched
DeeGee
24 Jul 2012
Great Grimsby
Reading Buses launched something similar here a couple of years ago. Under 19s can get a whole day ticket for £2.40 or any single for £1.40 with no ID necessary.
How does that work, then? What if 39 1/2 year-old me turned up and asked for one of those Solo tickets? Would I be asked to prove my entitlement? Or to explain myself?
JaJaWa
14 Feb 2013
"We reserve the right to ask older looking customers for identification from time to time. This scheme is designed for customers under the age of 19 only."
Presume they would only do so if you looked like you were taking advantage!
crehld
1 Nov 2014
Norfolk
As promised, an example from a Northern TVM at Settle. As you can see this is a much better implementation of the new style compared to some of the other examples above. No overlapping text (although admittedly there's no reservations to get in the way on my example), but, more importantly, I believe the font is clear and legible, even with my arm outstretched a la my long-sighted mum. It doesn't look messy at all.
I suggest it is the font that is the issue on certain types of TVM, not the design per se (which I think is a vast improvement). I imagine fonts are stored as software on the offending TVMs so it couldn't be too difficult to get it fixed.... could it??
bb21
Emeritus Moderator
4 Feb 2010
Unfortunately S&B machines have one of the worst designs for printing speed and font legibility imo and print some right ugly tickets, but it would seem that they are favoured by some TOCs. They are imo the worst ticket machines I have ever had the misfortune of using.
I can see their engineers simply taking the spec given by ATOC and implements them without a second's consideration as to whether they would come out right.
crehld
1 Nov 2014
Norfolk
Picked this one up today. Anyone up for identifying the error?
I do find it amusing that these new tickets no longer mention anything about a specific TOC restriction on advances.
crehld
1 Nov 2014
Norfolk
I guess there's no point given the ticket will tell you precisely which train you must take. It's redundant information.
suzanneparis
21 Feb 2015
Why can't it specify what trains it is valid on? Otherwise it is hopeless because in my experience different staff will tell you different things!
Well, a sort-of error - it's not in any meaningful sense refundable, nor exchangeable, because the fee (£10) is higher than its value.
I know that's intentional, of course, but it is very slightly misleading :)
In a sense, but given that if you have to take another train because of disruption you're meant to stick to the same principal TOC (i.e. comply with the route marker) it can be useful.
Hadders
27 Apr 2011
For some ticket s you'd need a book rather than a couple of lines to list all of the information!
Thankfully there is a link to the exact restriction code on the National Rail website referenced on the ticket.
True but without a specific TOC restriction it strikes me that it is much easier to argue that you can, in the event of delays, take the next available train to your destination regardless of operator rather than waiting for the next train by the operator your ticket is restricted to as there is no longer an operator restriction printed on the ticket.
crehld
1 Nov 2014
Norfolk
True, but the advance ticket terms and conditions merely state:
If delays occur while travelling, you will be allowed to take the next available train(s) to complete your journey.
It's therefore always been easy to argue you can take the next available train regardless of operator!
Apparently they do now :(
So we're now back to potentially debating over which rule 'trumps' which rule :| Although in practice passengers are often allowed to take the next train regardless.
450.emu
21 May 2015
Mainly to do with what type of software is communicating with the Newbury Data printer (these are replacing the Swecoins across the network, the Swecoin character set is more blocky)
crehld
1 Nov 2014
Norfolk
Not the ones I picked up today!
Indeed. Whenever I've been delayed on advances and sought to travel on the next available train by a different operator I have always been allowed to do so. (In fact the only place I've come across the TOC specific rule remaining in force when delayed is on this forum)
It probably depends on the operator who set them. I've asked the forum member who experienced this if he can reply to this thread (it wasn't me!)
Also, FGW Advances are not - at least a few of weeks ago - printing at all in the new style format and revert to the old format.
crehld
1 Nov 2014
Norfolk
Does it depend on the operator who sets the ticket? Or the operator which programmes the TVM?
If the TVM is one which prints new style tickets, it will print in the new style if the operator who sets the Advance fare has set it up to print in the new style template, I believe. Or maybe it's the other way round and they all default to the new style unless they've opted out.
The only ones I am aware of which do not print in the new style are FGW ones but the situation may have changed since and I'm not sure if all other possibilities have been tried.
JaJaWa
14 Feb 2013
Ones printed by machines other than Parkeons do. I think I saw a FGW one that referred to it as "Unknown TOC", which is potentially why they're blocking new-style tickets at the moment.
Starmill
18 May 2012
Bolton
There is a lot of confusion and inconsistency. Parkeon machines have printed AP TOC ONLY tickets before in the 'Valid only on the following services and appropriate [TOC] Connecting services' even if the reservation is from your origin to your destination. I've also seen quite a few cases where a non-Parkeon machine has not bothered with any of that and just gone for 'Valid only on the following serivce'.
TEW
16 May 2008
I've seen FGW Advance tickets in the new format recently. Most if not all FGW TVMs have switched to the new format over the last couple of weeks too.
ji459
1 Mar 2011
Is the new design being used on tickets issued by ticket offices or just on tickets printed by TVMs?
lyesbkz
1 Dec 2010
Chesterfield
There are definitely a few bugs that still need ironing out with the printing of these new style tickets and reservations. Also, there surely could be a more intuitive way of representing where no particular seat reservation is issued (i.e. Arriva Trains Wales).
