New Super Voyager number position
headshot119
31 Dec 2010
Dubai
Have just noticed that 221102 has its TOPS number at one end just below and left of the drivers door on the red panel, rather than the lower down black panel, is this going to be fleet wide or has someone just put it in the wrong place ?
Incidentally it has the number in the normal place at the other end.
NSE
3 Mar 2010
That's a point I'd never thought of. I think the only other class with numbers on the side is the Pendolino? Oh and the 43 and 91's. that said I'm not familiar with all the livery variants on operators
Crossover
4 Jun 2009
It's easier for people working on it in the depot is the reason I've heard repeated several times.
It does stand to reason. Doesn't overly bother me though, as I can usually work out the number from everything but the numbers on the front skirt anyway :P
DarloRich
Fenny Stratford
and it annoys the spotters ;)
I have seen it mentioned that it is easier to see the number when it is on the lower fairing when working in the depot at ground level.
jopsuk
13 May 2008
the numbers are however purely there for maintenance purposes. The day they figure out how to go about depot operations reliably without external numbers is the day they stop bothering to apply them
bronzeonion
1 Apr 2009
West London
I doubt it, what if a driver or guard finds a defect to write in the report book? There must be a whole load of other uses for the number out of the depot.
IanXC
Emeritus Moderator
18 Dec 2009
If you're struggling to identify a CrossCountry Voyager you're travelling on, a useful piece of knowledge is that the landing page for the Wifi service includes the unit number. I've been monitoring them for some time and have found them to be 100% accurate.
rebmcr
15 Nov 2011
St Neots
Pendos too.
GatwickDepress
14 Jan 2013
442s display their numbers on the side, just below the cab window. I believe in NSE days, the number was painted below the first passenger window from the driving end; on the white stripe between the red and blue. Somewhat of a uniqueness among Southern multiple units (395s aside)?
