LickeyIncliner
Princes Street tram stop (Edinburgh) seems to have undergone gender reassignment
This is true, no? I recall it changing a couple of years ago.Looking at the GWR and TfW areas, Copplestone is no longer a request stop on the Barnstaple branch.
Curious, should there be something on the map to make a weird pattern like this clear or is it one of those things that's so small as @mattpharrison said where not having it is a much better visual decision. I mean on an online map you could at least show something when you hover over it with notes about the station etc.I should have known better than to believe the National Rail site…
It is true. It is no longer a request stop. The map previously showed it as a request stop, along with Deganwy, Conwy, Penmaenmawr and Llanfairfechan, but has since removed the request stop flag at these stations.This is true, no? I recall it changing a couple of years ago.
Oh that's excellent! Hopefully the actual tram stop signs will get updated to match.Princes Street tram stop (Edinburgh) seems to have undergone gender reassignment
Avanti customers would certainly have a problem alighting at Rugeley TV as only two coaches would fit on Platform. The new 730 units that run between Euston and Crewe via the Trent Valley line can only open from three coaches out of the ten that's now run on there.I don't think Avanti stock have Selective Door opening do they?National Rail have released a new interactive map at https://railmap.nationalrail.co.uk/#/mapview which features some interesting anomalies.
Alresford (Essex) is listed as Arlesford (Mid Hants)
Southern apparently run services into London Euston
Avanti West Coast call at Rugeley Trent Valley
Only the 805/807 AT300 units have full ASDO. On the 390s, only the rear 2 or 3 coaches can be deselected as far as I'm aware.Avanti customers would certainly have a problem alighting at Rugeley TV as only two coaches would fit on Platform. The new 730 units that run between Euston and Crewe via the Trent Valley line can only open from three coaches out of the ten that's now run on there.I don't think Avanti stock have Selective Door opening do they?
