New Cross Gate - West Croydon engineering work tomorrow?
asylumxl
12 Feb 2009
Hiding in your shadow
I know someone who wishes to travel from Honor Oak Park to London Bridge tomorrow, and after checking NRES is rather confused.
The engineering works section of NRES says that no trains will be running and buses will run instead.
BUT then several websites say trains will be running between Caterham and London Bridge and calling there?!
So which is correct? Any help would be appreciated!
tempests1
3 Aug 2010
Haslemere
The possession is from 0100 Sat through to 0400 Mon.
On Saturday the following alterations will apply:
Buses replace trains between London Bridge and West Croydon via Sydenham, calling additionally at Crystal Palace and Selhurst
Trains between London Bridge and London Victoria via Crystal Palace will not run
Trains which normally run between London Bridge and Caterham will only run between Purley and Caterham. Passengers are advised to use alternative services between London Bridge and Purley
Trains from London Bridge to Tattenham Corner will be diverted to run via Tulse Hill
Trains from Tattenham Corner to London Bridge will attach at Purley and then run forward to London Bridge
Trains which normally shuttle between Purley and Tattenham Corner will not run
Trains which normally run between London Bridge and Uckfield will only run between Oxted and Uckfield. Passengers are advised to use alternative services between London Bridge and Oxted
Trains which normally run between London Bridge and Horsham will start / terminate at Norwood Junction
Trains which normally run between London Bridge and Tonbridge will run as shuttles between Reigate, Redhill and Tonbridge. These services will not call at London Bridge, Norwood Junction, East Croydon, Purley, Coulsdon South or Merstham. Passengers are advised to use alternative services to / from these stations
Trains which normally operate between London Bridge and Reigate will not run
87015
3 Mar 2006
GEML/WCML/SR
There are nothbound only services stopping at intermediate stations between Norwood Jn and London Bridge which are half-hourly Caterham - London Bridge services. Going southbound there is nothing fast or slow so presumably the Up lines are open.
Seems like Southern have made a bit of a mess in the gen they've sent to the NRE people, its really not very clear against whats actually happening - it might help if they actually bothered to have a proper service alterations section on their own website like most people manage to do...
Southern
19 Jun 2005
Folkestone, Kent
The fact it says London Bridge - Caterham services will only run to/from Purley is a bit misleading. What, I believe, will actually happen is the diverted Tattenham service will convey a portion for Caterham, to be detached at Purley. Services from Caterham are given 10 minutes at Purley to await the Tattenham service, which will attach and then proceed all stations to London Bridge via East Croydon and Sydenham.
ert47
28 Feb 2010
The southbound trains are going fast from London Bridge to Crystal Palace and then all stops from Norwood Junction. Probably will be the same on Sunday
Southern
19 Jun 2005
Folkestone, Kent
Selhurst on the Southbound today, Northbound services very busy as can be expected with no London Overground...the lone 377/3 working the 1715 from Tattenham Corner didn't help, must be all Southern could get out.
