New Barnet Reversal
bb21
Emeritus Moderator
4 Feb 2010
Does anyone know what is going on around New Barnet here?
Tomnick
10 Jun 2005
Single Line Working, at a guess - all Up trains over the Down Fast?
GNERman
8 Oct 2008
North Yorkshire
It looks like they approach New Barnet on the Slow, work to signal K133, which is a shunt signal south of the station, reverse back into New Barnet on the Fast and go from there.
bb21
Emeritus Moderator
4 Feb 2010
That makes sense. Cheers for that. I wasn't sure where K133 is hence the question.
High Dyke
1 Jan 2013
Yellabelly Country
Engineering work. Found this info from Network Rail.
TRAFFIC REMARKS
0230 FRI TO 2200 SAT
UP TRAINS TO TRAVEL OVER THE UP FAST LINE BETWEEN BARNET SOUTH CROSSOVERS AND FINSBURY PARK ? UP TRAINS UNABLE TO CALL AT ALEXANDRA PALACE, HORNSEY OR HARRINGAY
FCC TO OPERATE AN HOURLY DOWN HERTFORD SERVICE
2200 SAT TO 0230 MON
DOWN TRAINS TO TRAVEL OVER THE DOWN SLOW 1 BETWEEN FINSBURY PARK AND NEW BARNET OR DOWN SLOW 2/DOWN HERTFORD BETWEEN FINSBURY PARK AND BOWES PARK.
UP TRAINS ? SINGLE LINE WORKING OVER THE DOWN FAST BETWEEN BARNET SOUTH CROSSOVERS AND FINSBURY PARK. SINGLE LINE WORKING SECTION TO BE SPLIT AT ALEXANDRA PALACE
CAPACITY = 4 TPH
CAPACITY ALLOCATION = 2 FCC & 2 EC
GRAND CENTRAL & HULL TRAINS TO TERMINATE AT PETERBOROUGH AND CONNECT INTO OTHER SERVICES
NO UP SERVICE FOR ALEXANDRA PALACE, HORNSEY OR HARRINGAY
FCC UP SERVICES NOT BOOKED THROUGH THE SINGLE LINE TO START/TERMINATE AT POTTERS BAR
FCC TO OPERATE A RAIL SHUTTLE SERVICE BETWEEN GORDON HILL & STEVENAGE OR HERTFORD (NO FCC SERVICE SOUTH OF GORDON HILL ON THE SUNDAY)
Tomnick
10 Jun 2005
Thanks, thought it might be that! Good to see SLW being used occasionally in preference to buses - I didn't think we were far from a world where no-one knew how to do it any more!
Assuming you're referring to the Up Fast, quite why they'd need a shunt to access the Up Fast when there's a perfectly good facing move, I don't know!
455driver
10 May 2010
Down trains are using the down slow line.
Up trains are using the down fast in the up direction, taken from High Dykes post above yours-
So both up lines are closed.
Tomnick
10 Jun 2005
Indeed, I'd worked that one out in my post further up the page! I couldn't resist questionning the other attempts to get to the truth though ;) .
CBG2KGX
15 Jan 2011
Cambridge
Rather tediously FCC appears to have cancelled a number of fast services on Good Friday (mentioned on their website but not in the NRE bulletin related to this engineering work). These were showing in NRE a few weeks ago but have gone now and are showing as CAN on realtimetrains. I guess something went wrong in the planning there.
ash39
8 Feb 2012
This morning (easter Sunday), I was on the 0800 York-Kings Cross, which was electric propelled by 91105.
At New Barnet it was announced due to engineering works we'd have to stop at New Barnet station, reverse back onto another line and then go forward to London. It was all performed by the same driver as i saw him walk down the platform.
Can anyone shed any light on why such a move was required?
RM-Taylor
7 Mar 2013
Grimsby
They did exactly the same for all London bound EC trains on New Years day, trains travelling northbound weren't affected though.
Dr.iver
19 Feb 2011
between New Barnet and Finsbury Park you travelled under single line working on the down fast in the up direction, hence the movement at New Barnet to take you from the Up lines to the down fast
jopsuk
13 May 2008
noted that the Kings Cross-Kings Lynn service appeared to be working as 12-car south of Cambridge today- even outside of the "peak" period for Boat Race travel.
Skimble19
12 Dec 2009
They did the same yesterday, leading to a fair amount of overcrowding on Peterborough route services.. Unfortunately, none of the remaining services were extended to 12 car (unlike the poster aboves experience), no doubt due to the extra staff required at various stations.
