Network Rail SHL test
Daysaver
7 Oct 2011
Hello people
Just a quick question , a friend has applied for a signaller position with NR and has been sent an online test to complete via SHL
Has anyone come across this test before ? What does it involve ?
Thanks
Johncleesefan
4 Sep 2013
Where has your friend applied and what job?
I sat one which was a situational judgement excersise. It was 16 questions/scenarios where you have for options for each. You have to tick the most effective and the least effective responses. Takea 20mins.
Hope this helps
Daysaver
7 Oct 2011
Hello, thanks for that , if it is the same thing then yes it does help
Grade 3 signaller, Talacre box North wales
kbreen
27 Jan 2014
Did this test a few weeks ago, like said Situational judgement test, just use common sense and give the answers that an employer would want you to give!
Good luck to your friend.
svrdan
28 Oct 2012
Tipton
Yes its an SJE, and you just answer what you would do under the scenairos etc, just completed one for Marsh Brook SB and awaiting the next part etc..
TomBoyd
2 Sep 2013
Some of them are a bit odd, and i'd recommend thinking about the 8 NTS skills while you complete them. Some of them obviously refer to things like 'planning and decision making' and a few of the answers aren't quite common sense, but by and large, you should be fine.
