Network Rail interview feedback
Jam67
10 Feb 2011
Lincolnshire
Hi, could I ask if anyone has ever managed to get feedback from Network Rail following an unsuccessful application or interview?
Thanks,
Kevin
29 Aug 2010
Yes. Was very good too, they even took the time to call me not so long ago and ask me to apply for a different job. Bit hit and miss though as I do hear many others aren't too happy with them.
Simon11
7 Nov 2010
Although not 100% related
I applied for TFL graduate scheme, got through to phone interview before being declined. Didn't receive any feed back.
But around 6 months later they have the cheek to ask me to fill out a feedback form on their process. The cheek......
The Informer
2 May 2011
Roy's Rolls Cafe
You will get some sort of feedback, usually through the post. NR's H.R dept aren't the quickest bunch at the minute. Your not the only one waiting for feedback anyway. ;)
Redviper
7 Jan 2011
I have applied for a couple of jobs with NR
Not received a jot of feedback, when I have logged into the jobs section of their website it says “application accepted” however that’s the last I have heard from them.
I would love to work for NR I regularly see vans about where I live so I know that its feasible – I would even work for free if it meant that I could just be part of the team (seriously).
The problem is I never went to university, and In a job where I am trapped in a office all day – you would not associate me with any kind of rail work – but (even if I say so myself) I am eager to learn and hard working.
But ill keep on applying and take it from there I just wish they would open a door for me and let me in! – until then Ill keep on knocking!
The Informer
2 May 2011
Roy's Rolls Cafe
Erm....your problem is the maintenance aint employing until they shed a bit more staff through voluntry redundancies and retirement. There is still a long process of slotting displaced staff into various key roles and until then they won't remove the recruitment cap. One way in though could be to show some interest in their apprentice scheme!
Jam67
10 Feb 2011
Lincolnshire
Cheers, that sounds promising then, probably just my impatience getting to me - I have found it a bit of an uphill struggle sometimes, to be honest, though.
I recently received an e-mail saying that an application had been unsuccessful, but they could offer feedback by appointment if I contacted Recruitment Processing. So I did that, but received an immediate reply to say that they were unable to feedback at the 'pre-interview stage of an application'... I let them know that I had actually had an interview for the job, but since then it's all gone quiet, unfortunately...
Yes,they rung me up.What job did you apply for?
Hi Mac, I'm hoping to become a signaller eventually, but it seems to be taking me quite some time... :)
Cheers for that, and everyone else's comments - thanks
I will send you a PM once you have made 5 posts
Intriguing... :)
From what I've seen, it's not their policy to give feedback on an application if you don't get to the interview stage, which is fair enough, but feedback after an unsuccessful interview (of which I've now had two) would be useful.
I possibly have a similar issue to you, in that I've been a professional archaeologist for the past 23 years (the last seven self-employed), which a lot of people don't consider to be a proper job :D
mac
15 Dec 2010
Becoming a signaller, like all rail jobs is not easy to many apply for to few jobs,its a job that when you get it you never leave.
Jam67
10 Feb 2011
Lincolnshire
That would certainly be the plan :D
In the end, it's just a case of banging in the applications when I can & plugging away until I get somewhere (or at least until someone tells me it's not worth bothering, hence the need for feedback). I believe they also now operate a 'pool' system, whereby your details are kept on file & you may be invited to apply for vacancies before they're advertised externally (as mentioned by '185' earlier in the thread), which sounds like a step forward, so who knows?
Onwards & upwards!
Kevin
mac
15 Dec 2010
I've been told my details are on file but they still tell me to fill app in when job comes up,i've done 4 in last 6 months and been interviewed twice.
Jam67
10 Feb 2011
Lincolnshire
Pretty much the same here - I've applied for five this year & had two interviews. Three of the applications are still active, one of the interviewed ones was unsuccessful & the other I should find out about either tomorrow or early next week...
The Informer
2 May 2011
Roy's Rolls Cafe
Even NR's own staff have to fill in an app form to apply for different jobs. Even though H.R have all their details anyway.
mac
15 Dec 2010
where abouts are you? I don't no how they decide who to pick i sent the same app in 3 times only changed the date and got 2 interviews with 2nd and 3rd,now waiting on 4th but they are very slow.
Jam67
10 Feb 2011
Lincolnshire
I'm in Lincolnshire. I guess the time it takes to work through the process is largely down to the number of applications they're receiving - there seems to have been a greater number of vacancies posted in my area so far this year & I was told the other day that there were several others that haven't yet been advertised externally, too. Even if there are only half-a-dozen applicants for each post, that's still a lot of folks to sift through.
mac
15 Dec 2010
Good luck with your latest try. Do you change what's on the application form or just leave it the same and just resend it
Jam67
10 Feb 2011
Lincolnshire
Cheers mate, I can but hope :D
Regarding the application form, I generally keep the information the same, as the majority of it is factual stuff that obviously doesn't really change. I do, of course, check it each time I submit one, just to make sure that the passage of time hasn't invalidated anything (or in case anything new needs adding, for instance the date of my most recent successful assessment, etc.) & make sure the details are actually correct for the particular job I'm applying for, but that's about it.
mac
15 Dec 2010
have they told you anything yet? Im waiting for them but they seem to have fault with website because not been able to log in since thursday.
Jam67
10 Feb 2011
Lincolnshire
No nothing yet - I'm down to my last two fingernails, so hopefully I'll hear something soon :D
Re: the website, I think they've been modifying it over the weekend as my original link to it's gone dead. By a roundabout route I found that the new link is: https://ebus2.hiav.networkrail.co.uk/OA_HTML/OA.jsp?_rc=IRC_VIS_HOME_PAGE&_ri=800&OAPB=IRC_BRAND&_ti=1797909368&oapc=3&OAMC=1006396_1_0&menu=Y&oaMenuLevel=1
Hope this helps,
Kevin
mac
15 Dec 2010
thanks for that,just checked but got an unsuccessful.Don't no how they decide when app is the same and closing date was only last night.
Good luck with yours let us no how you get on.
Jam67
10 Feb 2011
Lincolnshire
Sorry to hear that mate, better luck next time, I guess - just a case of plugging away until you get somewhere... :roll:
mac
15 Dec 2010
I will keep trying,thing is my father used to work on railway and if i had wanted a job then could of had one no bother but i went into lorries,been trying for 10 years now to change.
