Network Rail has responded to the ORR draft determination of its CP5 funding (2014-19): http://www.networkrail.co.uk/public...period-5/response-to-the-draft-determination/
Basically NR has refused to accept the determination and wants "at least £1.4 billion" added back by ORR to deliver what it is being asked to do in CP5.
The reasons are many and various, but seem pretty fundamental:
This does not look like a set of minor quibbles which can be fine-tuned out.
More like a "line in the sand", essentially saying if you want all the CP5 work to happen, you have to pay up for it.
I should think this debate will last until just before CP5 starts next April.
The detail in the linked document doesn't go down to individual projects, but basically NR thinks that ORR has picked an unrealistic line on efficiencies to be delivered, while not recognising the cost increase pressures.
I noticed in a quick read there are dark hints that the MML, East West and Northern Hub projects are going to cost more than expected.
Happy bedtime reading.
page 14 (gives page numbers where more detail can be found)
– The scale and pace of change proposed is unrealistic and the Draft Determination is not a balanced package 15
– The regulatory regime is more intrusive and complex than is regarded as appropriate in other sectors 20
– The approach to monitoring and measuring our business performance is complicated and includes hurdles based on subjective measures 25
– The investment framework should support a broad range of opportunities including efficiency, safety and R&D 29
– The capacity and performance framework is inconsistent and potentially inflexible 36
– The assumed cost of financing is too low 44
– The projections of property income are unrealistic 47
– The proposed level of expenditure on information technology is inadequate 50
– The expectations on track and signalling unit costs and efficiencies are unrealistic 53
– The assumptions on other renewals are also unrealistic, and the consequences from the framework for buildings needs to be clarified 61
– The proposed efficiency for the management of inflation is unprecedented and unrealistic 65
– The enhancement framework needs to be sufficiently flexible to manage the portfolio efficiently 70
