Network Rail Class 950 to be disposed
Class15
30 Dec 2021
North London or Mildmay line
I don't know for sure but I presume it could have been.
The 950 is quite rare in London, this is the only time I've ever seen it about down here , most test trains here are 153's so due to the rarity of it ending up in London I presume it may have been the last London outing.
It came to London in March - see:
Assuming the trips are roughly 6 monthly, it probably has at least 1 left but I’m not sure.
Here is a picture of it this evening on its Ferme Park to Derby run, for anyone interested.
Image shows the 950 passing Gospel Oak, with a Class 378 in the background.
Earle Grey
19 Sep 2023
Argate
It's running on a Z headcode to Slateford today, strange to see it use 2Z08 , Doesn't it normally use 2Q08 ?
Correct, it is like some of the earlier units/trains run from the RTC which used a single headcode to identify the type of train. Occasionally it would be planned to run as 2Z08 - a full transit between two locations when no recording was being undertaken; although I did note it running as a 5Z08 once, but when I was involved with it a full transit would be rare, there was little down time for the unit. I also had it out running as a 2X08 when circumstances dictated.
JR36512
24 Oct 2023
Essex
Quite a strange scenario, as it has almost been a year since this post and it is still being used! For example, Thu 11, Fri 12, Sat 13 it is doing the vast majority of the GEML!
It is running under 2Q08 headcode.
sad1e
26 Aug 2024
At this rate i highly doubt it will end up disposed of by the end of the year , my bet is summer next year.
XCTurbostar
13 Sep 2014
950001 is apparently currently undergoing an engine change so theres life in the old girl yet!
dan4291
9 Dec 2019
County Durham
It's been parked at Ferme Park today. Looked clean but can't see it getting an engine change there! Looks like it's working this today: -
RedPostJunc
10 Aug 2021
Andover
Most likely a refurbished one that's come from Wabtec Barton (Formally LH Group).
I saw 950001 at Reading Triangle Sidings last Saturday (07/02/2026)
Real Times Trains has 2Q08 2128 Reading Triangle Sidings to Reading Triangle Sidings via Aylesbury and Greenford for 06/02/2026
(I believe 2Q08 is its allocated head code)
Jacob Porrett
28 Jan 2022
Telford
When is 950001 meant to stop running (lite it was suppose to) because I saw it pass through Oakengates this morning on 2Q08 from Derby to Swansea.
fgwrich
15 Apr 2009
Hampshire
When they have a suitable replacement for it? Simple as that really. There was no definite date for it to have previously come out of service, although it, and some of the other yellow fleet, do remain on borrowed time.
Jacob Porrett
28 Jan 2022
Telford
I've been told September this year now they have got the 153s up and running.
XCTurbostar
13 Sep 2014
There is work for the TRU well into next year. It should be noted that the 153s (VIUs) and 950 (TRU) are not intended to compete. The TRU is part of the IM fleet whereas the VIUs are region specific.
Not all the 153s are operational.. yet.
D365
29 Jun 2012
And if the Network Rail IM (infrastructure monitoring) team is sensible, they / Porterbrook will set one of the 153s aside as a dedicated ETCS first in class unit.
But that’s obviously off-topic; I can’t imagine that any of the Class 150s (or 950001) will ever be fitted with ETCS.
Jacob Porrett
28 Jan 2022
Telford
Time will tell then I suppose. It's working 2Q08 tomorrow from Shrewsbury to Derby via a trip around the West Midlands.
pokemonsuper9
20 Dec 2022
Greater Manchester
Just to note for the readers not aware, 950001 is 2Q08 and 2Q08 is 950001.
I think there is the occasional 2Q08 that is not 950001, and 950001 sometimes runs under other codes when it's not monitoring, but they are near one and the same.
I am not sure how they expect 950001 to develop time travel, and depart Shrewsbury before it arrives tomorrow.
Given the same 09:36 to Derby path is also in on 03/06/2026, I think it may be present tomorrow in error.
A realtime trains screenshot showing 2Q08 (09:36 to Derby) departing Shrewsbury sidings well before 2Q08 arrives from Landore T.M.D (where it currently is)
XCTurbostar
13 Sep 2014
It will only ever run as 2Q08 or 2Z08 regardless of its duty.
The other VIUs also have a system of headcodes but thats outside the scope of this thread.
Roger B
16 Jun 2018
Gatley
Very interesting XCTurbostar.
I've been trying to track-down 153384 in its NR guise for a few years now. Are you able to advise what headcode(s) 153384 usually runs on please, and whether these are exclusively used by 153384 or shared with other units.
That would be a tremendous help - many thanks
XCTurbostar
13 Sep 2014
153384 is the second (Track Condition Monitoring Unit) TCMU2
It usually runs either with its partner (TCMU1) 153379 or on its own as a headcode ending in 4. E.g. 2QX4. the TCMUs aren’t as reliable to see as the VIUs though and are regularly swapped for others and maintenance. The VIUs are region specific so it’s much easier to spot. 153385 is currently the Southern VIU, for example.
Back on topic, I believe the 2 car TCMU will replace the TRU eventually since it is much more equipped and more modern for the same task - as for when, I guess it depends how much work it has!
Roger B
16 Jun 2018
Gatley
Thanks again Turbostar - really helpful info.
XCTurbostar
13 Sep 2014
TRU - June
3rd June 2026
9th June 2026
10th June 2026
11th June 2026
13th June 2026
15th June 2026
16th June 2026
17th June 2026
18th June 2026
19th June 2026
20th June 2026
24th June 2026
26th June 2026
Intercity_225
13 Jan 2024
March
Here we go then people, get photos of it while you can...
On her way to her farewell tour of Scotland today for the week. She will be making an appearance in Yorkshire from the 27th of July for the week before she heads south before being decommissioned at the end of September. Sad times !
A comment on the post says the following:
Ben Mcsporran
Are we definitely sure it’s being decommissioned as I have heard this story before…
Daniel Sandow
Ben Mcsporran supposed to be September it gets shut down for good. Thats why at least 1 153 at long marston is being prepped to join network rail fleet with the others
Gary Lane
Ben Mcsporran I'm one of the drivers and yes. She is going.
Towers
30 Aug 2021
If it doesn’t end up being saved somewhere, somehow, it’ll be a travesty!
DBS92042
13 Apr 2019
950001's chassis is reported (by a Loram employee) to be very rotten and without significant work wouldn't pass its upcoming exam in September, hence retirement.
Towers
30 Aug 2021
Wonder if they’ll strip her for spares to keep Northern’s /1s going, in that case…
