Network North Electrification Projects
Class 170101
1 Mar 2014
Please explain how electrifying Felixstowe-Ipswich would not eliminate diesel haulage on West Coast container trains? Are they still going to diesel haul under the wires to/from Felixstowe?
Would need to electrify the destination though. Some of them are not wired either. So the freight just continues as diesel all the way.
They had a good route for freight but they ripped it up has they didn't want to change from 1500dc to 25kv.
Not believing anything the daft say about the railways in the north anymore.
Could Woodhead take W10 containers? And how would they get there from Felixstowe etc?
Djgr
30 Jul 2018
I started this thread for a rational discussion on the electrification projects announced ("We will electrify...") by the Prime Minister on October 4.
I didn't expect a fantasy debate on lines totally separate from those announced.
You may not believe government announcements but it's all we have, until there is a change of government.
Don't you believe he actually cancelled HS2 Phase 2? - I'm sure he did.
There is, apparently, £36 billion to spend on the alternatives, of which, if you believe him, £1 billion is for North Wales electrification.
Given the context of the current government, its competence, trustworthiness and likely longevity, anything and everything within this thread is purely speculative and should be located accordingly within the forum.
Cestrian21
7 Apr 2021
Wales
Absolutely this. It's hard to see how we can treat any of these announcements as anything other than a fantasy wish-list unless/until it has a Business Case in place.
Killingworth
30 May 2018
Sheffield
The Woodhead route was indeed designed to carry freight, primarily coal in 4 wheeled wagons (as was the Hope Valley). None of the Pennine tunnels wete built with modern containers in mind and nor was the rest of our infrastructure. Improving it all to take modern containers is desirable but needs joined up planning.of practical priorities.
Electrifying the major freight flows would with the use of much more powerful electic locos allow freight to better keep out of the way of passenger trains as well
The timetable is designed to do that. Electrifying freight could, in some cases, enable shorter passenger journey times and/or more capacity (if it is needed where it can be released).
I wonder if a say 90mph 1000tonne frieght is practical.
If it was, we would have had it already (assuming you mean freight in the conventional sense. We already have 100mph freight with parcels services).
Why are we electrifying at all then.
Because there are good (very good) business cases for doing so. Just not many for freight only lines.
You didn‘t say that. You said:
electrify Felixstowe to Ipswich which would eliminate diesel locos on freight using the WCML
Theres a lot of freight on the WCML that doesn’t go to or from Felixstowe. And even that which does go to or from Felixstowe, much of it has a non electrified line the other end. Hams Hall, Lawley St, Birch Coppice, East Mids Gateway for example.
Why do you agree with me about Felixstowe-Ipswich in post #117 after insultingly questioning my understanding of economics?
Because from the numbers I’ve seen there is, probably, a case for Felixstowe to Ipswich. Also London Gateway, and maybe Nuneaton to Birmingham. Not much else though with primarily freight benefits. At £12m/mile of double track railway, you need to save a lot of diesel and carbon, and lots of other benefits, to make electrification pay.
ac6000cw
10 May 2014
Cambridge, UK
I wonder if a say 90mph 1000tonne freight is practical.
Here are a few recent discussions about running higher speed intermodal trains:
https://www.railforums.co.uk/threads/high-speed-intermodal-flat-wagons.234279/
https://www.railforums.co.uk/thread...omotives-e-g-classes-99-93-88-be-used.251127/
https://www.railforums.co.uk/threads/class-93-tri-mode-loco.210779/post-6375057
The gist of it is that the technology isn't a problem (provided you can get enough power from the OHLE), it's economics i.e. making at least some profit out of it.
A pair of 90's (if allowed to use full power, which they're not at present) would give you 10000hp/7.7MW, and a pair of 88s or 93s even more, and 90mph capable intermodal flats (with payload weight restrictions) have been around for years.
As an example, note that a 16-coach Caledonian Sleeper (based on vehicle weight listed on Wikipedia) is nearly 700 tonnes trailing load, so a 23-coach sleeper would be around 1000 tonnes (and would be shorter than many intermodal trains).
I did see the Acton Bank link had come back into consideration for wiring.
This was not just for freight, but to permit some GWR diversions into Euston during Old Oak Common (GW station) construction.
It's only half a mile or so, but highly strategic.
class ep-09
5 Sep 2013
GWR 800’s are bio-modal .
Indeed, and not much use for freight! There‘s loads of train paths in the timetable using that link, but maybe only 10 each day that actually run that could swap to electric traction. And that assumes the terminals the other end are electrified, which in most cases they are not, as they are stone terminals and need top access.
I agree it needs doing though, as it’s the sort of link that will find new uses when electrified, eg for empty passenegr trains.
Class 387s / Class 345s aren’t…
stssts1985
21 Aug 2022
Some of these are never going to happen!!!
While we're on the topic, we should electrify
-Cleethorpes - Barton on Humber
- Middlesborough to Whitby
- Stockport to Stalybridge
- the Brigg line (high speed ready)
jonesy3001
13 Jul 2009
Otley, West Yorkshire
They could redouble the track between guide bridge and stockport and rebuild the junction near ardwick so they can stop reversing trains at ashburys, now that hs2 isn't coming to manchester.
eldomtom2
6 Oct 2018
Electrifying a long route principally for the benefit of freight will have decarb benefits, but in the scheme of UK emmissions, it eont even register. The taxpayer will get far, far better Carbon reduction benefits from paying for improving home insulation, or heat pumps, or home generation systems,or ICE car scrappage, etc.
Is your suggestion that freight rail should not bother with decarbonisation? If it is, I doubt the industry will be seeing any more government handouts in the future...
It was to get Crossrail stock around OOC when the line is shut for HS2. Im not convinced we will see GWR in Euston.
There are hundreds of schemes that would be worth spending cash on than that.
Not at all. My point is that there are far better uses of scarce capital funds than electrifying lightly used routes where freight may be a beneficiary.
I’m flattered that you think me commenting on a public forum will influence government policy. It hasnt worked to date.
class ep-09
5 Sep 2013
And why would they need to go to Euston ( even if there was a capacity ) ?
They are to terminate at Ealing Broadway , turn around at Acton West and go back towards Reading.
Its a serious proposition from GWR. The paths have been looked at.
I could imagine the West Country sleeper using Euston, if there's room, though that wouldn't need wires.
Heathrow Express passengers wouldn't thank you for terminating at Ealing Broadway.
eldomtom2
6 Oct 2018
What do you suggest for the problem of freight rail decarbonisation then?
You misinterpreted my point. My point was that if freight rail loses its perception as the "environmentally friendly" method of freight transportation, it will lose government support.
What government support is that?
In the short to Medium term, Class 93 and Class 99. Coming to a railway near you soon.
ac6000cw
10 May 2014
Cambridge, UK
In any case, using diesel engines for the last mile is definitely a stopgap solution.
We don't have any electric locos with just 'last mile' diesel capability in the UK (a mid-1960s class 73 is more capable than that, and an 88 even more so). I think if you were designing 'last mile' capability into an electric loco now, I'd expect it to be battery powered.
ROG with the cl. 93 and GBRf with the cl. 99 are being pragmatic about what's possible to fit in a UK size and weight loco at present, to get locos that can do what they need for their business in the near future (at a cost that's affordable) while making it 'greener'. Perfection can be the enemy of progress...
eldomtom2
6 Oct 2018
That definitely hasn't been the impression I've gotten from discussions on this forum!
