[Netherlands] Registering card on OVPay
AdamWW
6 Nov 2012
Does anyone know how I can register a new card for OVPay?
Whether I try from the app or my browser, and on different networks, I just get "403 Forbidden" when I try to register a debit card.
DanielB
27 Feb 2020
Amersfoort, NL
You don't need to register a debit card to use it for OVpay. When you mean adding it to your account: I just tried to add one using the app and got to bank-selection with no issues.
AdamWW
6 Nov 2012
Yes they do make that very clear. I should have said adding rather than registering.
If I add a card to my account I can then see the journeys I've made (and, if I recall correctly, also get real time information on taps).
I have no problem getting as far as bank selection but when I get to the bit where I should enter the card number I get an error.
The same error occurs if I claim to have an account with one of the listed banks.
And if I try to add a credit card.
Maybe the method using an "NLOV" code having made a journey will work. (I think that's what I did previously when adding a card).
johncrossley
30 Mar 2021
I just tried the same thing and I also get "403 Forbidden"
Then I tried it using a VPN, setting it to the Netherlands, and it works.
DanielB
27 Feb 2020
Amersfoort, NL
Sort of realtime yes, it sometimes is slightly behind. And their processing of daily caps is broken at the moment and shows weird things (when reaching the cap the fare before discount is also displayed as being € 0)
Sir Felix Pole
21 Oct 2012
Wilmslow
Sounds very much like the OV-chipkaart organisation. They have/had similar blockages.
Yes, foreign bank accounts are barred - although Belgian and German ones are not. It is infuriating as It it means I can't take advantage of the OV-fiets bike hire available at stations.
DanielB
27 Feb 2020
Amersfoort, NL
You should be able to hire an OV-fiets when having NS Flex which can be purchased via NS customer service. Even the basis-variant is enough to hire an OV-fiets.
johncrossley
30 Mar 2021
The problem is getting the card delivered outside the Netherlands, Belgium, Germany and Luxembourg. With the OV-Pas that problem should be fixed as the card can be purchased from Primera.
rvdborgt
24 Feb 2022
Leuven
That's "IBAN discrimination", which is forbidden... I know they're working on it and the plan is/was to accept other bank accounts "after the summer" this year. But maybe it helps if you report this case.
If you live outside of these countries you should contact OV-chipkaart customer service via chat. I don't have any experience having a card delivered there, but they don't exclude it explicitly anymore.
kkong
8 Sep 2008
But is it?
Under the SEPA Regulation, some situations are not considered IBAN discrimination
Card payments and cash withdrawals from ATMs
The SEPA Regulation and the ban on IBAN discrimination do not cover payments you make with your debit card or credit card for online and physical purchases, nor do they cover cash withdrawals from ATMs or bank branches.
