Need some help please
Jim Jehosofat
17 May 2017
Daughter needs a ticket for a return trip from Attleborough or Diss to Heathrow T5, outward on 4 July and return on 14 July.
Outward would be either 9.16 from Attleborough changing at Norwich or 10.17 from Diss. Homeward journey depends on flight arrival and any delays getting through immigration, so can't be tied down to a particular train, but wouldn't be before 8.15.
What's the best ticket to purchase for this journey.
Thanks
Haywain
3 Feb 2013
Is that 08:15 for the return or 20:15? And does she hold any railcards?
Your daughter would probably be best off travelling from Diss, buying an Off-Peak Return from Diss to Hayes & Harlington, and then an Anytime Return from there to Heathrow Rail. This would cost a total of £84.70 and would provide complete flexibility on the route and time of travel. The Elizabeth line provides a one-change option (easiest at Stratford, but also possible at Liverpool Street if the chosen Diss train doesn't stop at Stratford) so that's the obvious option for getting to Heathrow.
If she could commit to a specific train on the way back - which I realise is difficult due to the vagaries of flight delays - then it could be done quite a bit cheaper overall, as a combination of Advance tickets costs only around £22-25 each way booking this far ahead (again, generally splitting at Hayes & Harlington). I suppose one option would be to book Advances in each direction and then to change the time of the return tickets (subject to payment of the fare difference) if the flight is significantly delayed. In the worst case scenario, a series of split walk-up tickets for the return journey should cost no more than around £60, so she still be no worse off than buying the above combination in the first place.
However, this approach does rely on your daughter having internet access at the point where she realises she will miss the train though, so it's a question of whether the saving is worth the hassle. Noting she is flying from Terminal 5, the vast majority of BA and Iberia aircraft do have WiFi - but a handful aren't fitted with it and it's always possible for there to be a technical fault or a lack of coverage for part of the flight. Very slow WiFi (marketed as being for messaging, but also suitable for text-based web browsing) is free on both airlines if you create and sign into an account with them.
In terms of buying the tickets themselves, if your daughter does decide to go for the split Advance ticket option, in my view she would be best to do this via a retailer that doesn't charge admin fees for changes. Options for this include CrossCountry, TPE, Railsmartr and Ticketyboo. Of those, I believe Railsmartr is currently the only one to also suggest split tickets.
Jim Jehosofat
17 May 2017
Thanks for your detailed reply. She says she will probably go for the £84.70 fare using Dad's taxi service to get to Diss
drueberflug
26 Jan 2025
Germany
I'd just like to remind you that you or your daughter do not want the Day Return ticket in this case, as you may get to choose between the Anytime Return and the Anytime Day Return for the Hayes and Harlington to Heathrow section. The latter saves you a few pence but is only valid for one day in total, and would not allow for a return trip on another day (unlike the Anytime Return, which allows for a return journey within 1 month).
Also, for your daughter's convenience, stick to paper tickets as the journey involves a cross-London journey and your daughter probably won't want to deal with e-tickets and paper tickets (which are mandatory for the cross-London section) at the same time; however, this is purely personal preference.
