The following changes to the routeing guide were published on Thursday.
Changes from 24 Jun 2022 (390) to 30 Jun 2022 (391).
Easement changes:
contain SSD CBG HIT SVG HFN AAP FPK KGX
Added:
701005 (Map) Due to engineering works, on the 13/14, 20/21 and 29 August 2022, customers travelling from Stansted Airport to central London or via central London may travel to London Kings Cross via Cambridge and Hitchin. This map easement applies in both directions
701006 (Routeing Point) Due to engineering works, on the 13/14, 20/21 and 29 August 2022, customers travelling from Elsenham (Essex), Newport (Essex), Audley End, Great Chesterford, Whittlesford Parkway and Shelford (Cambs) to central London or via central London may travel to London Kings Cross via Cambridge and Hitchin. This routeing point easement applies in both directions
The closure seems to be between Harlow Town and Waltham Cross. Web sites use a more generous version of 701005, so you can obtain an itinerary (say) from Stansted Mountfitchet to London via Cambridge.
Changed (added sections in red, removed ones in green):
701003 (Local) Customers travelling to Smithy Bridge or Littleborough, may not not doubleback from Rochdale. This negative local easement applies in both directions.
This removes the double negative from the description.
701004 (Map) (Local) During engineering works on the 16 and 17 August 2022, tickets from Worcestershire Parkway to Swindon and beyond may travel via Cheltenham, Gloucester and Bristol Parkway. priced on (00807) VIA STROUD, (00808) READING STROUD INCLUDING LONDON, (00803) EVESHAM/STROUD, (00827) LONDON STROUD/EVESHAM, (00418) AP KEMBLE/SLOUGH and (00417 AP KEMBLE NOT LONDON will be valid via Yate, Cam & Dursley and Bristol Parkway for journeys to and beyond Swindon.. This map easement applies in both directions
This has changed a bit. It's now a "local" easement which only affects the section between the first and last routeing points in the route. It does mean that (according to nre.co.uk) a Worcestershire Parkway-Swindon "via Stroud" ticket is valid via Bristol
Incidentally, none of the "Kemble" fare routes exist for journeys to or from Worcestershire Parkway, only the "Stroud" ones.
Route changes:
NOT HS1/LONDON (00902) (416 records)
must not go via London Blackfriars (BFR), London Charing Cross (CHX), London Cannon Street (CST), London Fenchurch Street (FST), London Bridge (LBG), London Liverpool Street (LST), Stratford International (SFA), London St.Pancras (STP), London Victoria (VIC), London Waterloo (East) (WAE), London Waterloo (WAT) or Farringdon (ZFD)
must include tube
This prevents use of the ticket from some extra London terminals.
The following changes to the routeing guide were published yesterday.
Changes from 30 Jun 2022 (391) to 01 Jul 2022 (392).
Easement changes:
Removed:
701000 (Circuitous Route) Customers on journeys from or via Ash Vale that also include travel via Farnborough Main may not travel via Woking. This circuitous route easement applies in both directions.
This easement was in place for 2 1/2 weeks.
Added:
701007 (Circuitous Route) Customers travelling to or via Leamington Spa with tickets priced on (00211) VIA COVENTRY may not travel via Tyseley. This circuitous route easement applies in both directions
The version web sites use restrict the scope of this easement to journeys which go via Coventry (as "via Coventry" tickets are also valid via Dorridge). Easement 700121 already prevented a "via Coventry" Leamington-Northampton ticket from being used through both, but this extends it to other tickets such as Mortimer-Northampton.
